Power - 4AGE ITB's and Stand alone ECU?
03-14-2007, 12:27 AM
I am just wondering who has fitted the throttle bodies from a 20v unit, and what sort of power they got? any tips?
I have just ordered a Perfect Power XMSL ecu, I have used this on other engines and seems to work quite well. I plan to run it with a Peugeot coilpack and run wasted spark. I have also jus bought a set of 20v throttle bodies and a Technotoytuning adapter plate to fit them, can't wait. I plan to get the ecu running on the standard injection first.
My engine is stock at the minute, just a homemade exhaust and air filter fitted, going to the rolling road on sat morning to see what it is making before I start.
Ivan
any info on the conversion before I start would be great.
1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1
03-14-2007, 01:05 AM
Very interested to see how this goes. Wish I could help you out.
03-14-2007, 11:12 PM
Why not run on stock ignition ?
Finn
03-14-2007, 11:56 PM
I think alot of power can be gained from mapping the ignition and it will give me greater control over the engine. plus I don't think the standard ecu will work the the quad throttle bodies, so needs to be stand alone.
Cheers
Ivan
03-17-2007, 05:41 PM
byd1380 Wrote:I think alot of power can be gained from mapping the ignition and it will give me greater control over the engine. plus I don't think the standard ecu will work the the quad throttle bodies, so needs to be stand alone.
Cheers
Ivan
Yes, but i mean, why run on peugeot coil pack, and not let megasquirt run stock ignition ?
Woops sorry, thought you had megasquirt..
Finn
03-17-2007, 07:17 PM
PM SENT.
At last Itsuki is gone.....:o)
Who the hell is Itekani??
lol...Wataru! ????
03-19-2007, 12:35 AM
Took the car to the rolling road on Sat, I will try and attach the printout, it made 118.6bhp at the flywheel. I just wanted to get a baseline figure before I put the ITB's on it.
03-19-2007, 03:03 PM
Hello
I had a standard engine with just an air filter, header and HKS exhaust. It made 116bhp with 148,000km on the clock.
I have just had AE101 throttle bodies fitted with 272/7.9 TODA cams, 0.8mm head gasket and Apexi Power FC ECU. It makes 140bhp at 7,800rpm and the power was still climbing. Need to get some high strength con-rod bolts (and an engine balance, it doesn't half vibrate at that speed) to get some more revs so I can get more power.
Both power figures are using regular petrol in Japan, that is 89 Octane.
I hope this info helps
03-19-2007, 11:19 PM
Thanks, that's exactly the kind of info I'm after, looking forward to starting into it now.
Cheers
Ivan
02-27-2009, 12:45 AM
Ozone Wrote:Hello
Not for much longer hey stuart......
http://www.elitetech.co.uk/ae86.htm - should be a cracking project!
  Ecu for AE86 4AGE Steller Engineering 6 7,745 03-10-2021 11:06 PM
  ITB convert need standalone ECU izanagi 2 8,025 04-07-2016 11:24 PM
Last Post: izanagi
  4age 16v oem ecu rev limiter research ditn 18 33,071 06-22-2015 08:02 AM
Last Post: ditn
  4age 16v 1st and 2nd generation cams and not only difference Apsogos 3 8,787 09-16-2013 08:24 AM
Last Post: Apsogos
  Car shutting off and ECU making noise rawb_dbap 8 10,009 05-03-2013 11:51 PM
Last Post: rawb_dbap
