Piston rings ?
10-28-2007, 08:49 AM
Piston rings ?
Hello,
Is there any difference in piston rings between the small and big port ?
Replaced head gasket and piston rings 500km ago and it looks like the engine is using oil. Filled it up untill max on the dipstick and now it is half way between full and "empty".
Maybe it has to be broken in ?
I use different oil now, before I used Castrol 10w40 semi synt now using valavoline durablend 10w40 semi synt.
thanks
Jos
http://www.heerlijklimburg.nl
10-28-2007, 09:04 AM
Piston rings ?
I dont know if there are differences between the piston rings of the high and low compression pistons, but if your engine was using oil before, then you might also consider changing your valve seals.
10-28-2007, 09:25 AM
Piston rings ?
morning ivan Cool
we changed the valve seals together with the pistonrings and head gasket.
before the enigine was not using oil Undecided
10-28-2007, 04:27 PM
Piston rings ?
http://www.ae92gts.com/ae92gts_totalseal_info.html
"NOTE: Make sure that you choose the correct ring for your 4A-GE! Earlier 4A-GEs have a 1.5 mm #1 compression ring vs. the newer 1.2 mm #1 compression rings!"
http://www.ae92gts.com/ae92gts_engine_specs.html
[Image: AEU86 AE86 - Piston rings ?]
10-28-2007, 04:49 PM
Piston rings ?
the rings are different.... also you must have the correct hone to match the rings to get them to "bed in" properly
Dan -
10-29-2007, 09:12 AM
Piston rings ?
thank you will check things out ! Thumbs up!
10-29-2007, 09:14 AM
Piston rings ?
so the rings for the small port are the ones mentioned 90-93 in the overview Michel H ?
10-29-2007, 10:42 AM
Piston rings ?
for the late type. Yes, The other ones have the 18 mm pin.
10-29-2007, 11:42 AM
Piston rings ?
I think it is normal for the engine to burn some oil while breakin' in.
I've done almost 1500 miles and I already added 1 liter of Castrol RS Formula 10W60 100% Synth
Best regards
10-29-2007, 02:11 PM
Piston rings ?
thanks again Robokill & Apardal Thumbs up! Thumbs up! I just found out we used the correct rings
  Piston ID kazi 5 8,877 08-11-2019 03:34 PM
Last Post: totta Crolla
  86mm piston wizards... fantapants 6 9,658 05-30-2017 02:36 PM
Last Post: jdm86gtz
  Piston Identification Alex170984 3 7,854 05-17-2016 12:47 PM
Last Post: Alex170984
  Piston availability totta Crolla 3 7,705 09-03-2015 09:32 PM
Last Post: oldeskewltoy
  which piston is this? ditn 10 16,851 07-04-2014 03:18 PM
