Old Fashioned
04-07-2005, 12:40 AM
Post: #51
Old Fashioned
Sounds like your lsd is working, but I still say doing a donut is the best way to tell.
Dont worry about urethane bushings...if you can get rubber replacements cheaply then go for it. The important thing is that they are not worn out. I think you should probably paint the undercarriage with rust protecting primer and possibly even paint before putting on any tar like undercoating. About the waterpump, just turn it at the pulley and feel if it turns smoothly. If there is much resistance or if it doesnt turn evenly all the way around then it's either worn or in the process of wearing out. FABRICA MI DIEM, PVNC! |
04-07-2005, 08:45 AM
Post: #52
Old Fashioned
Tnx!
About the bottom side of the chassis.. yesterday i used a metal brush mounted on a powertool, so i started to remove al the little rusty bits. Looking at the other photos, my body is in pretty good shape.. hm.. thats sounded a bit gay i have also taken apart the bridge, arms, stabilisres etc.. i took all of that stuff to be sandblasted. The "steering-end-piece" and the lower arm will be taken to the shop where they will replace the "link-piece"... man my english sucks.. after that i will paint everything with primer color, and than with the rubber-based color.. that should be good for some 10 years. bushings are not in great condition... the most critical are the ones connecting the front and rear stabilisers (the small ones).. thet are cracked and lost their flexibillity years ago.. So where can i get all the bushings? i dont want polyur, just new rubber.. hopefully i can get someone with a cam to come and make some pictures. tnx for help! cu. |
04-07-2005, 02:55 PM
Post: #53
Old Fashioned
About brake lines, you give your old ones, and the man made you the same new. Price maybe about 15 € each.
About bushing, I order two bushing from specialist, and he made them for me. You need to give him metal in which your bushing are inserted, and he made new ones by speciment. Price about 35 € for me for pair of bushing on conecting rods on my LSD. You can chose 3 type of rubber, soft, medium and ( dont know the word ) You must give to both specialist a speciment of bushing or brake line. You can't order. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
04-07-2005, 03:49 PM
Post: #54
Old Fashioned
tnx Kas! i will first try to look around in our country, there must be someone who does this.
i also found a company which custom-builds links an probably bushings.. i will have a word with them, and we'll see. if nothing can be done i shall contact you. well my undercariage was finally sand blasted, just got them now and it looks great! and all this for les than 30eur! im thinking about sandblasting my springs too. Is that okay? or will the spring get damaged? now on with the primer coat.. so happy! will post some pictures when done..ciao! |
04-08-2005, 12:44 PM
Post: #55
Old Fashioned
Apolan, i'm about to sandblast some stuff to... what and how are you gonna do to protect and paint it?
Good luck with your project. Best regards |
04-08-2005, 10:08 PM
Post: #56
Old Fashioned
i will sandblast everything that can be sand blasted. i love it. it cheap and effective.
now ill just paint the stuff with a base (primer) color (red-brown) for metal.. than ill paint it with rubber-based color -thick layer.. thats it. you can than paint with some body color over that.. but i wont do tat for the undercarriage. |
04-09-2005, 12:44 AM
Post: #57
Old Fashioned
Apolan,
here we also have steel braided brake lines they are more expensive but you can also find complete sets at ebay. Always remember you got 7 brake lines total and then one line for the transmission part. /(clutch) Your going nicely but remember first build the car then worry about the lsd :-) Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-11-2005, 08:47 AM
Post: #58
Old Fashioned
Robo; when you said take 4 weeks off work.. worry not, i had quit my job just to be with my hachi 24-7.
yesterday i have painted the wishbones, arms, bridge.. with a primer color.. aint no rust comming through now! i have also put up the brake booster and cylinder. and also the clutch master, and release cylinder.. which is just dangling down there at the moment as i am yet to instal the trans. im not 100% sure i did the wireing (brakes, clutch) correctly.. i'll take some pics and youll tell me what you think. i have seen all the rubbery parts, and i will put all new. found a company here that does that.. ill see whats the price for steel braided ones and decide accordingly. question: is there no firewall on the outside of the car (enginme bay)? will post some pics from yesterday later.. dzana!
04-11-2005, 08:56 AM
Post: #59
Old Fashioned
okay here i have some questions.. 1) that thing in the lower right corner is a igniter coil right? 2) what is that thing-device in the upper left corner, just above the washer fluid tank? is it for wipers? there are milions of other little sensors, and tiny weeny thingis that i have no clue what they are all about.. ill post some pics, hopefully you can tell.. well my engine looks like this one (above).. can anybody please take some detailed pics of engine bay (closeup). it would really help me.. arigato. |
04-11-2005, 09:03 AM
Post: #60
Old Fashioned
![]() what is this thing in the lower left corner, just above the two green dots? fuel filter? and wher does the fuel pump go? in the engine bay, or back with the fuel tank? |
| danish renovation, from rusty old banger, to nice drift car | katapouser | 15 | 23,921 |
12-23-2008 10:41 PM Last Post: katapouser |
| Cp joels old school drifter (56k warning) | cp joel | 77 | 89,665 |
09-17-2005 01:21 PM Last Post: James |
| Jons New [Old Project] | JonT | 75 | 82,865 |
08-08-2005 04:26 PM Last Post: Blueneon |
![AEU86 AE86 - Old Fashioned [Image: AEU86 AE86 - Old Fashioned]](http://cosmos.oninetspeed.pt/apardal/carros/online/desmontagem/dsc00030.jpg)
