OIL:)
09-13-2004, 10:02 PM
OIL:)
KristianAE86 Wrote:hi guys.Do you run on white wall tires too?!? Mineral oil doesnt lube as good as synthetic. I wouldnt use mineral oil to a high reving engine, but if I had an old Escort it would be about right
09-13-2004, 10:03 PM
OIL:)
valvoline 10w 40
I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
09-13-2004, 10:05 PM
OIL:)
Hmm, valvoline, they sell that here at do it your self homebuilding stores for some reason...
09-16-2004, 01:33 AM
OIL:)
Clean oil is more important than how slippy it is.
You are better off using mineral & changing the oil every 3,000 miles with a top quality filter, than running a synthetic for extended periods. Changing synthetic & filter every 3k is VERY expensive. I use Castrol GTX 10W40 in the 20v and the 16v 4AGE. I get it cheap and it's a decent quality and the right grade for the engine and ambient temps. It's wise to keep the oil temperatures down (eg around 90 deg C) to prevent the molecular breakdown of the oil. Higher temperatures in forced induction engines often require expensive synthetics, but for NA 4AGE's, quality minerals are fine. The same goes for LSD oil - you may as well just use a decent mineral LSD oil and change it regularly. Regular changes with synthetic becomes soooo expensive. The amount of sludge that can be generated in an LSD is frightening. Leaving synthetic in for a year is just too long and the contaminants will damage the LSD. If you do a lot of drifting, you will need to change the oil every 3 months at least. I do mine every month. |
09-27-2004, 09:11 AM
OIL:)
Valvoline has this little advisor script on their website that will guide you through engine choice of your car. Interestingly enough the AE86 is actually mentioned within the list with recommendations
![]() This is what they recommend: Engine: Valvoline Durablend or Valvoline Maxlife engine oil (10W30, 10W50, 15W40, 20W40 or 20W50) Gearbox: Valvoline DuraBlend Gear Oil GL-5 75W90 Diff: Valvoline DuraBlad Gear Oil GL-5 LS Might be interesting to know
09-27-2004, 01:26 PM
OIL:)
mux213 Wrote:Valvoline has this little advisor script on their website that will guide you through engine choice of your car. Interestingly enough the AE86 is actually mentioned within the list with recommendations 20W40 is pointless and 20W50 is far too thick unless you live in the desert. As for GL-5 in the T50 gearbox, errrr no, since GL-5 lubricants contain an additive (sulphur I think) that is corrosive to our copper syncros... Best oil by far for the T50 is Redline MT90 (GL-4 75W90). |
09-27-2004, 01:38 PM
OIL:)
20vWill Wrote:20W40 is pointless and 20W50 is far too thick unless you live in the desert.Hehehe, well I didn't mention the temparature ranges they added to this information, just wrote down the weights they mention. 20vWill Wrote:As for GL-5 in the T50 gearbox, errrr no, since GL-5 lubricants contain an additive (sulphur I think) that is corrosive to our copper syncros...Could that be where the difference between GL-5 and GL-5 LS lies? If not someone should email valvoline to tell them they recommend oil that destroys equipment. Damn sorry I hear of it now though, should just throw the stuff in and sue valvoline and let them pay for my new TRD Diff 20vWill Wrote:Best oil by far for the T50 is Redline MT90 (GL-4 75W90).Need to figure out where I can get that here then ![]()
09-27-2004, 02:27 PM
OIL:)
Throwing GL-5 in your gearbox and then sueing them for a new diff would be a bit silly now wouldnt it? BTW, they probably have a disclaimer for all the advise they give you through the internet so I doubt you could even make a case. But since you where only joking who cares anyway. I never buy valvoline so I dont care either way.
09-27-2004, 05:39 PM
OIL:)
Hmm, didn't read your post well enough will, sorry
you were talking about gearboxs, I was thinking about my LSD![]() Ok, so GL-5 eats up the synchros of the gearbox, better not use that one then ![]() How about the diff then? Cause that is the one I am going to be changing on short notice... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
09-27-2004, 05:48 PM
OIL:)
Diff uses GL-5....it hasnt got any copper parts afaik. I have a bottle of MPM SAE-90W GL-5 lsd oil waiting to go into my diff at the next opportunity to put my car on a bridge (tomorrow possibly...I'm having my wheels balanced.
| trans oil, lsd oil change | Apolan | 9 | 22,525 |
| Oil cooler -> low oil pressure | Jan Pedersen | 24 | 40,919 |
| 4AGE crankcase gas and oil pressure too high, sprinking oil | demogun | 5 | 11,067 |
| Oil Presure and what oil i have to use? | CHACAMAN | 4 | 8,016 |
08-27-2008 05:35 AM Last Post: F0Bman |
| High engine oil temps - oil cooler discussion | SutteR | 28 | 34,111 |
06-08-2008 11:23 PM Last Post: eight-six |
