O2 sensor question
01-23-2010, 08:10 PM
O2 sensor question
Hi there just a simple question i have a tomei a/f ratio gauge in my car and it came with it own sensor which is attached to the top of the manifold.
[Image: AEU86 AE86 - O2 sensor question]
The original sensor has been cut. It runs ok at the moment (a little rich) will it be better to get a new sensor and connect it back into the loom.
Its running on standard ecu with a boxer field fueling computer
thx
Alex
01-24-2010, 01:01 AM
O2 sensor question
see if your tomei sensor puts out a dummy (narrowband) signal that you can wire into the loom. Lots of aftermarket sensor can do this (innovate for example) - that is if your tomei is wideband - if it's narrowband anyway then just splice it into your original loom.
if above is possible fit your tomei sensor in place of the original as the place on top of the manifold was intended for the EGR system and AFR/lambda sensor don't like too much hit for prolonged time (bosch ones are rated around 700°C)
01-24-2010, 03:49 AM
O2 sensor question
cool will check and have a go thx
Big Grin map sensor cheating? fdsjakl890 8 4,333 08-26-2025 01:12 PM
  Lambda sensor wiring sam3007 10 9,884 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 25,127 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 11,286 02-28-2014 10:07 AM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 14,666 10-25-2013 05:13 PM
Last Post: Apsogos
