New engine setup, what performance will I get?
12-11-2006, 07:48 AM
So I got new high compression pistons and I'm getting the head/block milled with a metal head gasket. The pistons are 11:1 and with the milling I won't be far from 12:1. I just got my Crower full race cams, 288/298 with less than 9mm lift. I'm running dual 40mm Mikunis, header, exhaust, and adjustable cam gears. What do think the hp/tq figures would be around?
I'm balancing the bottom end(OEM crank/rods), light weight flywheel, have MSD 6AL/blaster coil, and TRD valve springs if that matters any. Thanks, g |
| weir performance email | filh | 2 | 6,453 |
06-14-2015 05:37 PM Last Post: oldeskewltoy |
| 4 Link setup and Traction brackets | Jezza_hr | 5 | 13,235 |
07-21-2014 09:12 PM Last Post: Bean |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 10,808 |
| Can't get my car started! | phill 92 | 16 | 19,545 |
09-16-2013 05:23 PM Last Post: Alex170984 |
| Weir Performance rear upgrade kit for AE86 | heshan | 5 | 11,811 |
07-22-2013 09:11 PM Last Post: heshan |
