(New) Rear Brake Disc Width
07-06-2010, 04:26 PM
I have been searching all over the net for this with no luck... Does anyone know the figure?
Thanks! SFD |
07-06-2010, 08:04 PM
i will messure mine tomorow or day after...
they have ess then 100km so like new... |
07-06-2010, 08:06 PM
iirc it's 10mm
EDIT: just checked the manual front is 18mm (17mm minimum) and rear is 10mm (9mm minimum) ![]() You can find the manual on the frontpage in the Technical section (left lower side) helps a lot for things like that and more.
AE86 ex-daily |
07-06-2010, 09:56 PM
Thanks! Stupid me, didn't occur to look at the most obvious place!
I guess for 0.4mm it won't be a problem to fit a wilwood dynapro-2pot in the rear (says disc max width 9.6mm) I don't suppose anyone in the forum has done a similar modification? SFD |
07-06-2010, 10:04 PM
not done that modification but in worst case you will need to skim down the pad slightly if you can't fit the caliper over the disc
AE86 ex-daily |
| Axle width | totta Crolla | 1 | 3,447 |
| Switching diffs for disc brakes? | trippin | 6 | 6,488 |
07-08-2022 03:35 AM Last Post: trippin |
| Rim width. Which is best.... | Dino86 | 5 | 9,841 |
| Rebuild rear disc brakes toyota crown ms112 axle | bozu | 0 | 5,370 |
| wider rear axle,track width,suspension questions | ditn | 6 | 13,174 |
