New KAAZ 2-way installed: problems, please help!
08-28-2006, 11:07 AM
Okey guys, i had problems with my diff ever since i bought the car. i've rebuilt it a couple of times and spent a lot of money until i finally bought myself a brand new Kaaz 2-way lsd (zenki). Smile
[Image: AEU86 AE86 - New KAAZ 2-way installed: p...ease help!]
This time i decided to perform everything stricktly stricktly by the book. I replaced all bearings with koyo new ones, inspected the pinion and crown, inspected the halfshafts and replaced their bearings also. I prepared Motul 90PA as gear oil since we don't have KAAZ oil in Bulgaria.
The car was assembled. According to the KAAZ tech manual i'm supposed to perform a special breaking procedure. This basically means 30 minutes of driving in 8-line (eight line) at very low speed with the clutch in while doing the U-turns and the acceleration applied in the straight section.
More detailed info: http://www.kaazusa.com/techHelp/tech_Help.htm
So i went out to a big parking lot and started driving. From the very beginning i noticed some chattering noises while turning, but those were described as normal in the KAAZ manual. I had my 30 minutes of practice with a short interuption by the police at the 15th minute Smile Everything was looking good. I decided to try a couple of slides before going back to garage to change the oil. Drifting test also seemed successful. I headed back to the service shop and not long after, the following problem occured: Noticable only while turning (doesn't matter if in gear or not) i hear vibrations and clicking noises. The car has power to the wheels when turning so it's not broken halfshafts. I reached the service shop and we performed the following test: we lifted up one rear tire and tried to spin it by hand when not in gear. Then we tried the same with the other rear tire. Both tests were succesful, meaning that, altough with difficulties we were able to spin each tire, while the other was still on the ground. The interesting thing is that the mechanics told me they have tried the same procedure before i took the car out and at that time they could not rotate the tires. I don't know if this test leads to a certain conclusion, but decided to share it with you.
The mechanics called me this morning. They have taken out the halfshafts and they look good. This means that the problem should be further inside. I don't want to open the brand new KAAZ unit yet.
So anyone that have experience with similar units or installs, please, share your opinions!
Thanks guys!
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
08-29-2006, 10:11 AM
A-T-S 2 way mech diff in my Nissan.
One wheel on the ground, no way you can turn the other wheel when in the air.
Totally crazy problem and I have nothing else to say. I have read it 2 times and no clue. Undecided
08-29-2006, 10:13 AM
I have allready answered you in club4ag Smile
http://forums.club4ag.com/topic.asp?TOPIC_ID=148531
08-29-2006, 10:47 AM
gon Wrote:I have allready answered you in club4ag Smile
Thank you very much, once again! Smile
ZaX Wrote:A-T-S 2 way mech diff in my Nissan.
So is this the right way it should behave or not?! Confused
08-29-2006, 11:15 AM
In addition to the topic, here is the quoted replied of KAAZ to my situation:
Quote:Your unit is still brand new and very tight. So it is normal to hear some clunking, chattering type noise from the unit. The noise should go away after about 500 ~ 800 miles of driving or after the first oil change 3,000 ~ 5,000 miles. When the unit do have a problem, the car will normally pull to one side when going straight. Also it will become very hard to turn or no power gets transferred to the axle when it is slipping very bad. Put some miles and let me know how the unit is operating.
Best Regards,
Kaaz USA
  Big wheel problems gh0st 16 14,798 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 4,798 08-31-2021 06:20 PM
Last Post: totta Crolla
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 3,862 05-10-2021 01:02 PM
Last Post: Project D
  TUV RHD AE86 Germany (help please) 4dori 9 10,881 07-17-2019 07:42 PM
Last Post: Hachigo83
  Help needed: is it 1 way or 1.5way LSD Dino86 2 5,251 05-17-2019 09:08 AM
