Need info: Silvia S12
10-18-2008, 02:33 AM
Need some quick info, what do we have on the S12?
Engine 1.8 DET? Same as S13?
LSD? Its a US market car i m talking about.
Cheers,
A.
[Image: AEU86 AE86 - Need info: Silvia S12] http://www.jdmbits.com
10-18-2008, 08:42 AM
Hey nmwisima,
1.8 SOHC turbo, totally different engine from the one in the S13. Don't know about LSD though.
10-18-2008, 10:10 AM
No LSD, CA18et. Single cam 1.8 turbo. 140 bhp, shitty suspension, great look.
No more Panda..
Tricolor bastard!
10-18-2008, 11:31 AM
This particullar car has a DET. It has catalytic converter and its Turbo. Has 173 PS. Maybe uses a newer engine?
Can someone use on an S12 parts from earlier Silvias???
10-18-2008, 11:39 AM
the DET went in the S13 so i think thats the newer engine, yeah.
173 bhp in a S12 has to be big fun! Huh
The S12 is know as hard to modify, especially with the suspension..
No more Panda..
Tricolor bastard!
10-18-2008, 04:57 PM
Megan reacing sells a coiloverset for the s12.
front can be done with some s13/s14 parts, rear can be done with corvette shocks iirc.
10-18-2008, 10:06 PM
Thing is that Driftworks if full of S13-14-15 parts.
Engine ok. But LSD and brakes?
10-18-2008, 10:17 PM
AFAIK the 2.0 had LSD, but dunno about the 1.8...
I would go for the 2.0 which has a FJ20E, which can easily be swapped for the FJ20ET (Skyline R30 RS-X Turbo ), so IMO that's the better option. >Smile
(in Japan they actually delivered them to the Silvia!! Huh )
BTW: according to Wikipedia the later versions did feature the CA18DET:
http://en.wikipedia.org/wiki/Nissan_Silvia
10-18-2008, 10:20 PM
S13 diff should fit, open diff style
S14 diff is the same on the outside.. but viscous lsd on the inside, and another backhousing.
(S14 diff with S13 diff backhousing will fit S13)
S15 (Spec R) diff is also the same on the outside (Different backhousing again) And torsen.
(S15 diff with S13 diff backhousing will fit S13)
S13 should fit S12 with minor or no adjustments
Rokuichi Power !!
_________________________________________
Toyota Starlet KP61 2.0 vtec
10-18-2008, 11:37 PM
an s13 diff will never fit an s12 subframe.
http://www.club-s12.org/faq/general/s12_...atalog.pdf
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 6,963 11-05-2016 01:34 AM
  Injector sizes info ZaX 19 42,338 07-17-2013 01:54 AM
Last Post: jondee86
  frame/chassis rails info Tig 14 26,029 12-22-2012 10:38 PM
Last Post: Tig
  Collecting info for w58 conversion ditn 1 5,881 06-01-2012 08:59 PM
Last Post: ditn
  OER sk-itb set info corolla4agze 4 6,545 04-08-2012 10:56 PM
Last Post: corolla4agze
