Need help with the air sensor
09-08-2007, 11:22 AM
I dont quite get it.. you have a turbo timer, but the engine wont idle when you switch the engine off (when the turbo timer should take over)? If it idles when you run it, it should idle with the timer too, maybe you wired it incorrectly, causing some vital thing to switch off (ignition/fuel). As I understand it, a turbo timer is nothing more than a delay between the moment you turn the ignition key to off, and the moment that the ignition is actually turned off.
| Messages In This Thread |
Need help with the air sensor - Sgonzalez - 09-07-2007, 05:03 PM
[] - Ivan141 - 09-08-2007 11:22 AM
| Windshield. Need Help. | Roma_trueno | 13 | 24,630 |
02-02-2026 02:19 PM Last Post: totta Crolla |
| Need help installing replica "OEM" sideskirts | sheppardpat47 | 1 | 689 |
01-30-2026 11:16 AM Last Post: Ivan141 |
| Air conditioning R134A swap | sheppardpat47 | 2 | 805 |
01-22-2026 11:16 PM Last Post: sheppardpat47 |
| map sensor cheating? | fdsjakl890 | 8 | 3,077 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Need help identifying this! | takumi_mt | 4 | 2,978 |
