Need help anyone
10-14-2007, 08:06 AM
Need help anyone
Problem i have is when i drive my car norma its ok l but as soon as i put my foot down for a long period and and turn it off and try to start it again it doesnt go but m yignition lights go in but starter doesnt go .when i swing the key my lights goes dim and my dask clock goes dead then i must let it stand for a while before it will kick
can any one one tell me what it could be,as i cleaned the termainals and replaced the one checked all the cables ... |
10-14-2007, 10:09 AM
Need help anyone
Sounds like the starter motor is getting heat soaked somehow..weird. I would suspect one of the main shaft bearings in the starter, but probably a lot more knowledgeable people will respond soon.
10-15-2007, 08:58 AM
Need help anyone
hi
i checked the battery water and saw that one of the cells was low on acid water and filled it to the norm mark could this cause a problem |
10-15-2007, 11:40 AM
Need help anyone
Do you hear any sound at all???
any click click? If you turn the key some times does finally start? I had a similar problem and it was fixed with an inexpensive starter rebuilt..
10-15-2007, 11:42 AM
Need help anyone
It could cause it, but then you probably also have a starter motor which makes a half or one revolution and then dies. If that is the case, try to borrow a good battery from someone and try if that solves the problem. If not, then I think you have to look into this thread:
http://www.aeu86.org/viewtopic/starter-p...38/start=0 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
10-15-2007, 01:00 PM
Need help anyone
the ignition goes on but the starter does turn ..this only happens when i drive the car hard,but ignition on but not swing on the starter just my lights then dims out....
i filled up the battery acid water drove it hard and didnt do it again but will check later again.... |
10-15-2007, 05:05 PM
Need help anyone
I had the same problem with a dead battery once..so check that first.
10-23-2007, 12:13 PM
Need help anyone
Yup.... I'd go with the battery getting to the end of it's life theory !!
From memory, I believe that the output of an alternator is greatest at low rpm and drops off at higher rpm. Combine this with sustained high speed running and a tired battery, and you could get the situation you describe. Most batteries will recuperate to some extent after being run near flat. Adding water should not make that much difference, unless the cell was nearly dry... but you could get lucky As suggested above, check with another battery to see if things improve. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
11-22-2007, 08:19 AM
Need help anyone
ok i believe it is the starter charged battery which was 3months old so will replace or fix starter
11-22-2007, 09:18 AM
Need help anyone
If the battery is OK, then it is time to pull the starter out and get it
overhauled. Being a DC motor, you can have problems with worn or sticking brushes, worn commutator, faulty segments etc. If it sucks enough current from a healthy battery to turn the clock off, there will be some arcing or burning happening somewhere Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
| Windshield. Need Help. | Roma_trueno | 13 | 23,728 |
02-02-2026 02:19 PM Last Post: totta Crolla |
| Need help installing replica "OEM" sideskirts | sheppardpat47 | 1 | 457 |
01-30-2026 11:16 AM Last Post: Ivan141 |
| Need help identifying this! | takumi_mt | 4 | 2,733 |
| TRD ECU need help | ps13michi | 5 | 6,508 |
| Need some help | DJexor | 4 | 7,174 |
03-13-2018 05:37 PM Last Post: pack |
![AEU86 AE86 - Need help anyone [Image: AEU86 AE86 - Need help anyone]](http://img159.imageshack.us/img159/9409/39563944fwdsucksue7.jpg)
![AEU86 AE86 - Need help anyone [Image: AEU86 AE86 - Need help anyone]](https://www.aeu86.org/sticker-banner-468.gif)
