My project is finally drivable ***updated pics*** 3/31/09
03-05-2009, 12:34 AM
Bump for some more feedback
Slide to side worldwide!!
03-11-2009, 04:16 PM
Here is the new intercooler being fitted up I have to get a few couplers still also a pic of the front with the bumper off and the motor as it looks today.
03-14-2009, 05:32 PM
nice, who makes the turbo manifold? what kind of engine management system are you using?
03-17-2009, 10:30 PM
great setup man! keep up the good work. I also have the same questions as style86. I would love to do the same to mine.
Pedro Velado GT-S Owner
03-18-2009, 03:03 AM
The manifold is a no name off ebay that i re-welded and reinforced as far as tuning i am just using 4agze injectors with a vortech fmu (rising rate 12:1) and the afm trick to run better a/f ratio i have a wideband hooked up in the car. my a/f ratio is pretty good its around 12.5:1 under boost i plan on getting a megasquirt eventually though
03-18-2009, 08:20 AM
how about hp?
03-18-2009, 05:41 PM
I havent had it on the dyno yet so I dont know but im sure its around 225-250 at least, or least i would hope so with all the mods I have done
03-19-2009, 07:22 AM
really nice car you got there
can you provide me with some more infos about your turbo setup? I'm planning to turbo my 16v next winter and i'm just about gathering information on the different setups which intercooler do you use? what cam size? ignition timing? etc. |
03-20-2009, 11:41 PM
Supppppppppppppalova!!!!!!!!!!!
I really love your car man!!! Great!!!! Ex ITR JDM ![]() AE86 TRUENO LOVER
03-31-2009, 03:12 PM
As far as some specs, its a t3 garret turbo running 6 psi right now, 4agze injectors, hks cams and cam gears turned by an hks t-belt, TiAL wastegate, supertech dual spring valve springs and titanium retainers, arp head, main and rod bolts, spec stage 3 clutch, 4agze bottom end, bluetop head, vortech fmu and afm trick, innovate wideband a/f guage, greddy type r bov, and greddy boost controller. There are other odds and ends but cant think of them right now.
The a/f ratio is 12.4:1 under boost and around 11.5:1 crusing around. Drives real smooth with just the afm trick. It idles around 14.7:1 so thats is pretty good I think. Slide to side worldwide!!
| Adam's white, rusty levin...updated 23-09-2018!! | adomz | 150 | 173,858 |
09-23-2018 05:14 PM Last Post: adomz |
| RT's Levin from Azores (1st post updated 2015) | RT | 66 | 91,773 |
08-07-2015 09:15 PM Last Post: banpei |
| AE86 RESTAURACION FROM GUATEMALA SWAP 3SGTE updated Jan-2011 | CIVER | 44 | 79,123 |
03-09-2015 03:52 PM Last Post: RT |
| Its in Finally | Alex170984 | 3 | 6,830 |
07-16-2013 04:01 PM Last Post: Alex170984 |
| 86er's Track rebuild N2.??? Finally an update page 8 | 86er | 191 | 289,022 |
![AEU86 AE86 - My project is finally driva...** 3/31/09 [Image: AEU86 AE86 - My project is finally driva...** 3/31/09]](http://img9.imageshack.us/img9/1605/blitzhondaintegratyper.png)
