My new daily driver...a kind of grown up hachi.
07-31-2005, 12:11 AM
Supernice dailydriver Ian.
congrats I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
07-31-2005, 12:31 AM
hey mux - lets hope the french engine is better than french wiring looms - my old renault 19 16v had serious wiring problems to the extent the headlights and stuff would turn off without warning
The RX8 is also a lovely car - but I would prefer and FC FD turbo if I had a mazda. With all the traction gizmos turned off the z33 is deffo not a car for people who cannot drive. In the wet it brakes traction really easy. With it all turned on its quite easy to drive quickly. The hachi is still the better driving car - which is why I wont be doing any real trackdays in the nissan. There are very few proper road cars that can offer the level of involvement the little toyota can. Regards Ian. |
07-31-2005, 08:40 AM
Ian, well that is the reason why many people are questioning Nissans decision to start using their french partners engines (I believe renault?). All in all the engines in the Nissans are better then the french, but the french engines are alot cheaper and work just fine so...
Indeed, if you want to go sportcar the RX8 is a compromise, it is ment as a family car, so FC or FD is the way to go. I personally prefer the FC because I think the FD looks like a toy car. The FD is the faster and lighter of the two. You can get a 2001 FD imported from Japan fairly easily and compared to the Z they are alot cheaper Problem with all RX7s though, if you dont know how to treat them, you'll brake the engine within a year, and especially with turboed once, a blown apex seal means $$$$$ (which is why I stick with N/A FC ). Nice thing offcourse is that these engines are massively tunable without loosing durability. In the end, the Z is indeed a great car to drive. I did ment it was for people that cant drive cause of that traction controll I still dont like the way it looks to much though ![]() P.S. for a dialy driver I would by an RX8 because they are way more practical then a Z or FD. A nice FC-TII makes a very good dialy driver but a tad thirsty
07-31-2005, 11:50 AM
I m reading all this and cant stay out since i've driven both the cars
Yes mux Renault is Nissan's partner, so what? I hate Ranaults, but again so what? Ford is partner of Mazda, does that mean RX-8 behaves as a Mondeo?(which is preatty desend for a familly sedan by the way) He could buy a RX-8, for sure its a better balanced car, a car that needs balls -also when the esp is off, its a matter of choice. For sure the RX-8 is more sharp while the Z is brutal, but what the hec, you can drift with it all the time. Dont forget man that with an RX-8 you have to check -and from my experience, add oil every two times you stop at a gas station for fuel. Yes, the Ranesis holds the title of "2006 best engine" but it still has some of the old wankel problems and more important it works like a store, from 6 to 9 (rpm) Not ideal car for a daily driver, man. Edit: If I could buy one off those, I think It would be the 8, I 'm that kinda guy who likes to change oils every week or so... Maybe with the price difference (here is about 15.000 euros! I would turbo the danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
07-31-2005, 12:38 PM
That car is SO nice!
I'm sooo jealous at you! I need a Z one day myself! And about the Mazda Rx8 (oh, pronounce Rx8 in swedish and it's pronounced damn close to the swedish word for shrimp soup Keep the good stuff up, Ian!
07-31-2005, 02:57 PM
nmwisima Wrote:Yes mux Renault is Nissan's partner, so what?Very simple nmwisima, Renault makes cheap engines engineered for your average house wife's car, not engine's for sportscars (with one or two exceptions). When you compare the Renaults engine in the Z to lets say the engine in a skyline or the engine in the S15 it is a step backwards. When you buy a Z you buy a sportscar and you expect an engine designed for the purpose, not an engine chosen because it is the cheaper option... Nissan very simply was the better engine builder, but to expensive... nmwisima Wrote:Ford is partner of Mazda, does that mean RX-8 behaves as a Mondeo?(which is preatty desend for a familly sedan by the way)I have nothing against car manufacturers working together. The fact that the new Nissan Micra or Primera or whatnot has a Renault engine, thats all fine, if that makes those cars cheaper for your average man to buy, go for it! Same with Mazda and Ford, if they can make their cars cheaper by working together and sharing parts, by all means, do so... But you didn't see Mazda drop a Ford Fiesta engine into their RX8 luckely, the only flaw Mazda made (if you can call it that) is drop a sportscar engine like the Renesis (that in N/A form is about as powerful as the original twin turbo in the FD) into a sportsedan.. . nmwisima Wrote:Dont forget man that with an RX-8 you have to check -and from my experience, add oil every two times you stop at a gas station for fuel.Well thats the problem with Mazda, they never work out the design faults because they dont want the owners to be troubled with having a car that needs to be operated differently. The oil is a good example, they went with a compromise here. To lubricate the inside of the engine they are actually injecting tiny amounts of oil into the combustion chamber. Hence the car always uses oil. It also means that if you want to keep your car running good for a long time, you should change your oil more frequent then normal. Just think about it, the more dirty your oil gets, the more dirty oil you inject into you engine... Also with newer synthetic oils, most are not ment to be burned within the combusion chamber. That is the #1 reason (semi) synthetic oils are banned from rotary engines. For my RX7 I've changed the system. Ripped out the oil injectors and just mix 2-tact oils into my gastank. This means I always get oil injected into my combustion chambers that is meant for that task and I dont use up my normal oil. It also means I could go synthetic oil within my engine if I wanted to increasing the life of my engine even further. There are even people that go as far as hooking a separate oil tank up to the oil injectors (especially those using the 13B as an engine in their planes running them at far higher rpms). I've seen these engines being taken appart after many hours of use and compared to stock engines... man the difference is staggering... nmwisima Wrote:Edit: If I could buy one off those, I think It would be the 8, I 'm that kinda guy who likes to change oils every week or so...If I had the money to buy an 8, I would go and buy an FC instead, lighten it up, drop a renesis in there, supercharge it and go
07-31-2005, 06:16 PM
Mux I totally respect your 2.6hundred-something posts,
but I really dont get your problem with the 3.5 Z's engine... Torque and power from 1.500 to 7.500, does'nt brake (never heard of a broken Z's engine yet), and still can take tones off tuning! Edit: I just talk to 3 of my colleges to the magazine and to the Nissan PR in Greece, and noone remember Nissan have any part on that particular engine. So, no prob, go and get one ... danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
07-31-2005, 08:59 PM
Screw this....Ian i´m loving the Z, wish it was mine! congrats man, hope you will grow to love this car as much as your hachi.
07-31-2005, 10:14 PM
nmwisima,
Hehehe, man its just an opinion and my opinion is not truth so I just believe nissan makes better engines then renault so to go with a renault engine, awell... I'm no expert in these matters, it's more feeling then factual![]() Other then that, the Z is a very nice car, not my piece of cake, not my kinda styling, but driving it, must be a great sensation, renault engine or not, and in the end, thats what counts
07-31-2005, 11:42 PM
IT-HAS-NO-RE-NAU-LT-E-NGI-NE-IN-IT
P.S. Yes lets screw this conversation. Who cares! dRIFT IT 24-7 IAn danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end http://www.jdmbits.com
| Polish driver drifting with just his feet! | banpei | 2 | 7,030 |
12-15-2012 12:44 PM Last Post: BOOMEX |
| Lucky Starlet driver | S.K. | 1 | 4,452 |
07-06-2008 10:20 PM Last Post: S.K. |
| Bought me a new daily driver today :) | peter møller | 14 | 16,025 |
02-27-2006 09:07 AM Last Post: peter møller |
| New bits for hachi | Ian.G | 106 | 117,680 |
08-02-2005 09:55 AM Last Post: ZaX |
| Different kind of Toyota | peter møller | 9 | 10,933 |
05-01-2005 07:39 PM Last Post: ZaX |
