My little (not really...) project - Soon to be all done?!?
01-17-2008, 06:43 PM
Post: #331
Hey Jan,
The pulley can be a real pest, I bought a special tool to pull it off from haraldnyborg. I believe it was this: http://www.harald-nyborg.dk/merinfo.asp?...61&n=60100 And that cam-cover looks really bad... Going to be a pest to clean. Regards Lars Veiss, Denmark Currently [URL=http://www.aeu86.org/viewtopic/dk-ae86-renovation-and-turbo-project---now-driveable/t/2474/start=150[/URL] |
01-17-2008, 06:49 PM
Post: #332
Thanks but I allready got one... But I just can't get the bolt undone
01-17-2008, 07:21 PM
Post: #333
Judging from the way that head looks.. you're probably going to have to do more than just clean the engine. You only see that much gunk on seriously neglected engines, or engines that have bad crankcase ventilation setups like the CA18DET.
Oh, and put an airgun or electric impact driver thingy on that pulley bolt.. It usually gets the job done in under a minute. FABRICA MI DIEM, PVNC! |
01-18-2008, 04:54 AM
Post: #334
run a 4AC rear wheel drive water pump housing setup,then use a FWD water pump,u will have grind down the fins alittle.where the thermostat is on the back of the head capp it with a channel in it,the outlet in the pic above that comes off the head becomes ur top radiator outlet,
![]() ![]() on the exhaust side of the head theres an outlet at the back,capp that and put a fitting in there for a heater line. hope this helps if first u dont succeed,ur not trying hard enough |
01-18-2008, 05:23 AM
Post: #335
wow that head looks just like my old 20v
thats why i sold it cuz it looked like it never had a good day ever, plus 2lts are fun but ur car looks wonderful man, once u rebuild the motor i think u hould be fine looks like a rebuild is needed, Pass sells alot of the stuff for these now, "life begins at 8000rpms" - Going Racing |
01-18-2008, 09:07 AM
Post: #336
20vPETE Wrote:run a 4AC rear wheel drive water pump housing setup4AC RWD are rare here... All AE86 are GT's with 4AGE. Now I have to take off the head I might just as well do it like this: RWD 20V waterlines 86er Wrote:wow that head looks just like my old 20v thats why i sold it cuz it looked like it never had a good day ever, plus 2lts are funYeah I remember. But I'll take it apart and see how bad it is... Never rebuild an engine, but there is a first for everything
01-19-2008, 01:09 AM
Post: #337
even a RWD 4age housing setup will work.
man thats dodgey stuff there,no one in australia does that.alot easier to make a plate like i did if first u dont succeed,ur not trying hard enough |
01-19-2008, 07:07 AM
Post: #338
hi there. you can buy a water line kit from pass racing.. its pricey but it will be worth it. they also carry the dizzy relocation kit. talk to max, he might be able to give u a deal. and as for that stubborn bolt goes, heat it up w/ a torch (just the bolt head) untill red, then hit it w/ a impact gun. that should do the trick. good luck. ive always liked ur project, even tho its a hatchback :wink:
im doing the same to my coupe. ill be posting a thread as soon as i get more done. all ive been doing is buying parts. te72 wagon ae86 levin coupe project
01-19-2008, 09:47 AM
Post: #339
Pete, I was going to make a plate. But since I have to take the head apart anyway I'll do it the other way. I simply think its cleaner and it will give a bit more clearence to the firewall.
Projectrollas, I know I can get these kits! But why would I spend +$2000 (incl tax and shipping)? This will look cleaner (I hope!), be cheaper and work just as well. I am going to drop the dizzy since I'll be running a VEMS ECU ![]() Quote:ive always liked ur project, even tho its a hatchbackHahaha :!: Well thanks, I think ![]() I'll make sure to check it out! Even though it is a coupe... Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch
01-19-2008, 01:40 PM
Post: #340
looking awesome jan
keep up the pace
| (Catching up...) OST-082: Nope, never again... at least not without all the parts | oldeskewltoy | 0 | 3,481 |
| OST-066: I get all wavy (4AC content) | oldeskewltoy | 10 | 25,551 |
04-03-2020 04:29 PM Last Post: Power_uP |
| d3nso's little AE86 N2 build | d3nso | 27 | 46,298 |
11-13-2017 11:42 AM Last Post: mad.matt |
| Doc's KE20: - really coming together now | The Doctor | 548 | 693,544 |
08-03-2011 11:57 AM Last Post: The Doctor |
| NZ AE85 - soon to be BEAMS powered | Hachi Go | 46 | 88,037 |
06-24-2011 10:12 PM Last Post: [Walaki]D`Lair |
![AEU86 AE86 - My little (not really...) p...ll done?!? [Image: AEU86 AE86 - My little (not really...) p...ll done?!?]](http://img140.imageshack.us/img140/6386/picture009wq6.jpg)
![AEU86 AE86 - My little (not really...) p...ll done?!? [Image: AEU86 AE86 - My little (not really...) p...ll done?!?]](http://img525.imageshack.us/img525/396/20vengineqk6.jpg)
![AEU86 AE86 - My little (not really...) p...ll done?!? [Image: AEU86 AE86 - My little (not really...) p...ll done?!?]](http://i119.photobucket.com/albums/o128/localmike/stuff/jnc-forum-sig_01.jpg)
