My hachi is using oil! Smokin!!!!!!!
10-25-2006, 01:23 PM
Sat speed camera device would class as sat nav which aint allowed i dont think?????
I would like a taller first though! A straight cut ford box would be nice though! My car pulls to 7500 in fifth on a private strtch of road but wont rev any more! Guess its about 115 ish mph????? If I aint sideways, I aint trying hard enough!!!!!!! |
10-25-2006, 07:59 PM
Now Kipsy... or anyone else with a 4.8 diff is there any chance you could count how many revolutions the prop does for one complete turn of the rear wheel. The reason I ask is because I tried two different Standard Toyota T50 gearboxes in my car and both gave the same, but wrong speedo reading. My car is an ex-stage rally car so it may already be on a 4.8 diff or similar.
I guess the above idea would work ? Just done a quick check for you and on 13" wheels with 185/60 tyres your car would be doing 122mph @ 7500 rpm. Have alook here:http://www.johnmaherracing.co.uk/gearcalc.htm and here for T50 ratios: http://www.domsat.co.uk/pages/gearboxes.htm hth An analogue brain in a digital World |
10-26-2006, 07:31 AM
Ill have a look over the weekend if i got time! Im running 185/60 14s. 122 is faster than i thought! It used to pull just over 7k rpm with standard gearing- on a huge straight though
10-26-2006, 11:30 AM
It will be faster than 122 with 14" wheels 'bout 126
10-26-2006, 01:54 PM
Pretty good for a 1.6 then! You doing any events in wales before the year is out? Ive just done the Harvest rally in devon which is the only english event ive done.
10-31-2006, 04:19 PM
Bolton Midnight
Not in Wales..... but can't wait anyway !!! An analogue brain in a digital World |
10-31-2006, 10:17 PM
Or maybe not..... Bolton Midnight cancelled and I just cancelled a confirmed entry on the Preston in favour of it
| What suspension set up are people using? | kazi | 8 | 10,363 |
07-06-2017 05:26 AM Last Post: headrush |
| Using a different diff in an AE86 | megabob | 6 | 10,621 |
02-17-2015 03:37 PM Last Post: megabob |
| trans oil, lsd oil change | Apolan | 9 | 20,240 |
| Using stock gauges with an engine conversion | Escy | 8 | 10,004 |
10-04-2013 03:42 PM Last Post: Jezza_hr |
| Oil cooler -> low oil pressure | Jan Pedersen | 24 | 36,401 |
