My braaaakes, what about yours? [brake topic]
02-28-2012, 06:53 PM
Post: #31
Could you give a bit more info on this.
I would like to upgrade the brakes in the near future but due to regulations the mazda calipers are not an option and i dont really want them something like 1 piston calipers with arround 250/260 mm disks would be perfect . |
02-28-2012, 09:17 PM
Post: #32
panda_tureno86 Wrote:Just a quick note. this sounds very interesting. if I remember correct some prelude has the matching disc size (282) in 4*114.3. After doing some googling Honda Legend and NSX NA1 might also be an option. Does anyone have the OEM AE86 setup apart and can weight (caliper with or without pads), measure (distance of mounting holes to each other and hub center, offset of disc-center to hubface) all the bits? I just recently rebuilt my fronts but forgot to do it and don't fancy taking them out again. AE86 ex-daily |
02-28-2012, 11:39 PM
Post: #33
panda_tureno86 Wrote:Just a quick note. Is this true, I will replace mine. But how about rear? Need this badly! 1985 AE86 (ハチロク) Levin - Summer time daily driver |
02-29-2012, 02:48 AM
Post: #34
I use new of everything:
OEM caliper EBC disc EBC pads Steel inforced hoses Works fine in Sweden. However havent tried them in subzero, but I have no reason to doubt it would work in cold. ![]() ![]() Regards Håkan AE86 SWEDEN https://www.facebook.com/ae86sweden |
03-01-2012, 11:23 PM
Post: #35
Does the ae101 calipers and or disk fit on an ae86?
i think it would be perfect for me 255 mm disks and ae86 calipers or ae101 twin piston calipers.? Its hard to find info on it need to fit under 14'' wheels |
03-04-2012, 12:38 PM
Post: #36
oldskull Wrote:Is this true, I will replace mine. But how about rear? Need this badly! I think front brakes are who stops the car, rear are "only" a helper (....especially to drift If it can helps anybody: I use T3 Wilwood kit (Wilwood forged Dynalite + 280mm slotted and drilled disc), i had a problem because my brake booster - BMC are zenki...a bit small, the pedal was too soft. I replace the BMC for a Hiace's one (with starlet EP71 deposit because hiace's one touched the booster) and now is a bit hard...but works perfect!! The wilwood BP10 pads have the "cold problem" and i'm waiting to get the EBC Yellowstuff to replace ![]() ![]()
04-11-2012, 06:54 PM
Post: #37
bump
anyone knows any info on the honda civic ek9 front brake upgrade Couldnt find anything on the internet about it. do the calipers and the disks fit? I found some from arround the 260 mm range for the back stock calipers with the s13 adapterplate and disks looks like the way to go for me |
05-09-2012, 07:51 PM
Post: #38
Do there excist any ferodo DS2500 pads for the front i can't find them?
If yes can you give me the pad number,i need them urgent Sad |
05-09-2012, 09:13 PM
Post: #39
I found some EK9 caliper info here:
http://www.ek9.org/forum/brakes/16375-ca...3-ek9.html Apparently AE86 mounting hole span is 5.5" = EK9 140mm.
| Another suspension topic - The deal with droop | Jezza_hr | 27 | 35,363 |
05-31-2014 10:35 AM Last Post: totta Crolla |
| the many more 4AGZE questions topic | ditn | 39 | 48,729 |
05-31-2013 11:35 PM Last Post: ditn |
| Brake master cylinder for FC3S brake conversion | Hachi Go | 8 | 16,458 |
03-03-2011 12:06 AM Last Post: filh |
| YES, another Digital Cluster topic | kikefasa | 4 | 12,186 |
07-27-2009 07:13 PM Last Post: kikefasa |
| MAP vs AFM (splitted from smallport sale topic) | krijn | 12 | 14,463 |
10-15-2006 04:25 PM Last Post: NoHachi |
![AEU86 AE86 - My braaaakes, what about yo...ake topic] [Image: AEU86 AE86 - My braaaakes, what about yo...ake topic]]](http://www1.garaget.org/gallery/images/1/262/262-74c0592c465c8c6780347851a7718ee1.jpg)
![AEU86 AE86 - My braaaakes, what about yo...ake topic] [Image: AEU86 AE86 - My braaaakes, what about yo...ake topic]]](http://i142.photobucket.com/albums/r120/tomiRS/01022012614.jpg)
![AEU86 AE86 - My braaaakes, what about yo...ake topic] [Image: AEU86 AE86 - My braaaakes, what about yo...ake topic]]](http://i142.photobucket.com/albums/r120/tomiRS/01022012615.jpg)
![AEU86 AE86 - My braaaakes, what about yo...ake topic] [Image: AEU86 AE86 - My braaaakes, what about yo...ake topic]]](https://st.forocoches.com/foro/images/smilies/r.gif)
