My braaaakes, what about yours? [brake topic]
02-28-2012, 06:53 PM
Post: #31
Could you give a bit more info on this.
I would like to upgrade the brakes in the near future but due to regulations the mazda calipers are not an option and i dont really want them
something like 1 piston calipers with arround 250/260 mm disks would be perfect .
02-28-2012, 09:17 PM
Post: #32
panda_tureno86 Wrote:Just a quick note.
For street use. The Hondas EK9 calipers are direct bolt on.
this sounds very interesting. if I remember correct some prelude has the matching disc size (282) in 4*114.3.
After doing some googling Honda Legend and NSX NA1 might also be an option.
Does anyone have the OEM AE86 setup apart and can weight (caliper with or without pads), measure (distance of mounting holes to each other and hub center, offset of disc-center to hubface) all the bits? I just recently rebuilt my fronts but forgot to do it and don't fancy taking them out again.
02-28-2012, 11:39 PM
Post: #33
Is this true, I will replace mine. But how about rear? Need this badly!
02-29-2012, 02:48 AM
Post: #34
I use new of everything:
OEM caliper
EBC disc
EBC pads
Steel inforced hoses
Works fine in Sweden. However havent tried them in subzero, but I have no reason to doubt it would work in cold. Smile
[Image: AEU86 AE86 - My braaaakes, what about yo...ake topic]]
Regards
Håkan
AE86 SWEDEN
https://www.facebook.com/ae86sweden
03-01-2012, 11:23 PM
Post: #35
Does the ae101 calipers and or disk fit on an ae86?
i think it would be perfect for me
255 mm disks and ae86 calipers or ae101 twin piston calipers.?
Its hard to find info on it
need to fit under 14'' wheels
03-04-2012, 12:38 PM
Post: #36
oldskull Wrote:Is this true, I will replace mine. But how about rear? Need this badly!
I think front brakes are who stops the car, rear are "only" a helper (....especially to drift Big Grin)
If it can helps anybody:
I use T3 Wilwood kit (Wilwood forged Dynalite + 280mm slotted and drilled disc), i had a problem because my brake booster - BMC are zenki...a bit small, the pedal was too soft. I replace the BMC for a Hiace's one (with starlet EP71 deposit because hiace's one touched the booster) and now is a bit hard...but works perfect!!
The wilwood BP10 pads have the "cold problem" and i'm waiting to get the EBC Yellowstuff to replace
04-11-2012, 06:54 PM
Post: #37
bump
anyone knows any info on the honda civic ek9 front brake upgrade
Couldnt find anything on the internet about it.
do the calipers and the disks fit?
I found some from arround the 260 mm range
for the back stock calipers with the s13 adapterplate and disks looks like the way to go for me
05-09-2012, 07:51 PM
Post: #38
Do there excist any ferodo DS2500 pads for the front i can't find them?
If yes can you give me the pad number,i need them urgent Sad
05-09-2012, 09:13 PM
Post: #39
I found some EK9 caliper info here:
http://www.ek9.org/forum/brakes/16375-ca...3-ek9.html
Apparently AE86 mounting hole span is 5.5" = EK9 140mm.
  Another suspension topic - The deal with droop Jezza_hr 27 36,427 05-31-2014 10:35 AM
Last Post: totta Crolla
  the many more 4AGZE questions topic ditn 39 49,744 05-31-2013 11:35 PM
Last Post: ditn
  Brake master cylinder for FC3S brake conversion Hachi Go 8 16,867 03-03-2011 12:06 AM
Last Post: filh
  YES, another Digital Cluster topic kikefasa 4 12,417 07-27-2009 07:13 PM
Last Post: kikefasa
  MAP vs AFM (splitted from smallport sale topic) krijn 12 14,920 10-15-2006 04:25 PM
Last Post: NoHachi
