My Ride
03-24-2013, 10:48 PM
Post: #261
My Ride
hi boys and girls so today check oil level and water and then
http://www.youtube.com/watch?v=FTmjTtYc41s http://www.youtube.com/watch?v=4uM481TABIg http://www.youtube.com/watch?v=j1sKuVfgc0o this was my happy sunday I'm so JDM I put everything sideways. AE86 owner |
03-24-2013, 10:51 PM
Post: #262
My Ride
oh yeah Offspring make it much better then
03-24-2013, 11:01 PM
Post: #263
My Ride
hell yeah
04-08-2013, 12:00 AM
Post: #264
My Ride
04-08-2013, 01:35 PM
Post: #265
My Ride
|BUDA| Wrote:http://www.youtube.com/watch?v=kIyGihppfHw damn, what a sound. Hope you got it fix soon. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
04-09-2013, 03:01 AM
Post: #266
My Ride
i dont know what is broken some say its the pinion and ring ...
i have no idea if i have the 4.3 or other the car does 200kmh in the GPS at 7500rpm question is order 4.1 or 4.3 or 4.55 or 4.77 the car was super quick 0 to 200 I'm so JDM I put everything sideways. AE86 owner |
04-11-2013, 02:17 PM
Post: #267
My Ride
![]() I'm so JDM I put everything sideways. AE86 owner |
04-11-2013, 02:50 PM
Post: #268
My Ride
If you stick with the stock axle, the lower the ratio, the less teeth the crown wheel has, the bigger these are. In theory, that could mean a small advantage in strength for using a lower ratio.
However, since its the crown wheel that broke, I think the teeth count on that one stays the same, so maybe same strength? Also, chewing up pinions like this is often a lubrication or oil overheating issue. You might want to look into adding diff cooling before slapping in a new set. The diffs run hot stock, nevermind with added torque going through them. That's what I'm planning at least. You can also add seals to prevent oil from going into the rest of the axle (or at least, that's what I've read somewhere). A wheel to steer the front of the car A pedal to steer the rear |
04-11-2013, 03:16 PM
Post: #269
My Ride
i might go 4.11 since the car is super fast and i will try to put s13 diff radiator
04-11-2013, 05:10 PM
Post: #270
My Ride
|BUDA| Wrote:i might go 4.11 since the car is super fast and i will try to put s13 diff radiator Nice one! |
| Scrapper's ride | Scrapper | 30 | 42,727 |
09-28-2012 05:18 AM Last Post: kennedy8383 |
![AEU86 AE86 - My Ride [Image: AEU86 AE86 - My Ride]](https://sphotos-c.ak.fbcdn.net/hphotos-ak-prn1/533397_614298891932923_1655037023_n.jpg)
