My Ride
03-23-2012, 12:50 AM
Post: #231
My Ride
[Image: AEU86 AE86 - My Ride]
almost start the engine have to check injectors wiring
AE86 owner
04-05-2012, 09:14 PM
Post: #232
My Ride
it lives .....
need to work on vacum tubes to get a nice running engine
AE86 owner
04-24-2012, 01:28 AM
Post: #233
My Ride
AE86 owner
07-25-2012, 01:29 AM
Post: #234
My Ride
http://www.youtube.com/watch?v=obTykM8xeAw
Thumbs up!
AE86 owner
08-07-2012, 12:53 AM
Post: #235
My Ride
some test for 86 day Respect!
my clutch slips...
diff need tune
and some more bits
Thumbs up!
AE86 owner
08-07-2012, 02:11 AM
Post: #236
My Ride
Tune your front axle, you loose too much grip when you initiate your drift.
(Maybe your tyre pressure is too high on the front)
Also your suspension seems too soft (we can see it bouncing)
08-07-2012, 07:22 PM
Post: #237
My Ride
Thumbs up!
08-07-2012, 07:47 PM
Post: #238
My Ride
yea the rear seems to bounce all over the place. But i saw quite few good drifts, with a little tune it will be awesome. Thumbs up!
ハチロク
08-07-2012, 11:13 PM
Post: #239
My Ride
the front is soft and tire has some pressure
e have to see the problem with the clutch
AE86 owner
08-08-2012, 12:10 AM
Post: #240
My Ride
so my problem
i got a 4 kg flywheel and exedy stage 2 and the clutch slips at full pedal or under 4000rpm..
since the 4AGZE has almost 10kg flywheel is it the fast spin the problem?
in the pic there is my old flywheel an press plate with a contact area of 222mm has the oem clutch plate has 220mm
the almost new one is the exedy stage 2 press plate with have a contac area of 210 mm and the exedy clutch plate is 200mm. also the 4 kg flywheel as the same area 200mm.
just to test i will get the 86 std flywheel and press plate fitted with the exedy clutch plate
i got the 4kg and exedy kit 2 year ago so they are like brand new
also
opened my diff and the pinon and ring were ok and the backlash was fine but the diff made mutch noise when hot and shake the rear end of the car
when the kaaz 2 way was was opened it was full of tiny micro sand type due to the many disks of the lsd. it was blocking some oil holes
so i hope it will be fixed when cleaned
now it is on a lsd oil bath to get the disks soaked
hope to get news soon
AE86 owner
  Scrapper's ride Scrapper 30 43,896 09-28-2012 05:18 AM
Last Post: kennedy8383
