My Revised '80's Thrashbox
09-18-2009, 10:12 AM
(This post was last modified: 04-30-2015 02:04 AM by OnBail.)
Hi fellow AE86 proud owners.
Good to see the strength of the 86 on your side of the planet doing well. So far I am on my 3rd AE86 now (2nd one in Japan) and I ended up with this. It's still not where I really want it so it's still a work in progress. I'm sure that some here might have already seen my car on other forums from past and recent. Car specs (Last updated in April 2015) Base: Toyota Corolla Levin Chassis: AE86 WHEELS Watanabe Racing R-Type 14" x 9.0J @Front Watanabe Racing R-Type 14" x 9.0J @Rear ADVAN NEOVA Tires for Front NEXEN Cheapies for Rear Super Lightweight Duralumin Race Wheel Nuts (Some Japanese brand which I forgot) HBK 20mm longer wheel studs BRAKES ENDLESS CCA Brake Pads Vented & Slit Disc Rotors all round RUN MAX Braided Brake lines SUSPENSION BC Coilovers (for now, will get the dampers custom re-valved later or go with a DG5 setup) Cusco Adjustable Tension Rods (Caster Rods) with the Cusco reinforced mounts as well Nagisa Auto Adjustable Inner Tie Rods Nagisa Auto Adjustable Pillow Ball Outer Tie Rods TRD Reinforced Bushes TRD Rear Sway bar TRD Bushed Upper Rear Control Arms Custom made Pillow Ball (Rose Jointed) Adjustable Super Thick Custom Lower Control Arms DRIVE TRAIN OS Giken STREETMASTER Single Metal Clutch with Chromoly Flywheel (2011 released model) Run Max Braided Clutch Line TOMEI Technical Trax 2 Way LSD 4.778 Final Drive Kit (with 5.375 TRD ratio spare) Brake Booster removed (was in the way of the 100mm trumpets) ENGINE (New spec built by KAI ENGINEERING in Kanagawa, Japan) AE92 base Compression Ratio 12.8:1 Bore : 81.0mm Stroke : Stock 77.0mm Managed by Haltech Platinum Sport 1000 Engine loom is now all Haltech Autospec Flying Lead Kit Long AE101 Throttle Bodies Tec Arts 100mm trumpets Techno Toy Tuning 4AG ITB Billet Adapter plate TOMEI PROCAMS Camshafts INTAKE: 288 x 10.0mm Lift / EXHAUST: 280 x 10.0mm Lift (Custom made by Suzuki-san, the younger brother of the founder of Tomei Powered Inc.) I also custom made the lazer marking on the cams myself at Tomei. TOMEI Adjustable Cam Gears TRD 0.8mm Metal Head Gasket TRD Valve Springs Formula Atlantic Spec Cross forging Forged Pistons Tomei Fuel Pressure Regulator Type-S Tomei Fuel Pressure Gauge Trust Oil Cooler Kit (removed during winter) Aftermarket 4-2-1 headers Toda Racing Exhaust System (with the Toda decat pipe) BODY RUN FREE Fiberglass Front Bar RUN FREE Fiberglass Front Fenders (guards) RUN FREE Fiberglass Side Steps RUN FREE Fiberglass Rear Bar CBY Fiberglass rear hatch with the stock dampers (many other makes in Japan don't have this) Unknown Fiberglass Bonnet CUSCO 5 Point Roll Cage INTERIOR PRO DRIVE Japan deep type Steering wheel Recaro Bucket Seat (Driver Side) Bride Reclineable Bucket Seat (Passenger Side) Omori 52mm Oil Temp Gauge Omori 52mm Oil Pressure Gauge AEM Digital Wideband Air / Fuel Gauge TRD leather Shift Knob ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ok here are some extra images on my car with the engine bay and a bit more most are old and I know the engine bay needs a good tidy up too. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
-- JailBait -- Bait me! |
09-18-2009, 11:23 AM
09-18-2009, 11:46 AM
nmwisima Wrote: That about sums it up: location, road quality, car, friends' cars... |
09-18-2009, 03:42 PM
Very very very very very cool levin!
![]() Hmmm, featuring a newera imports sticker? Don't tell me Miguel re-imported it back from Ireland!? > 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
09-18-2009, 03:44 PM
your levin is so cool
I'm so JDM I put everything sideways. AE86 owner |
09-20-2009, 08:30 PM
thanks guys
banpei, no this car never left Japan. Miguel and I are good friends and I have had this car since 2006. It's still a work in progress! -- JailBait -- Bait me! |
09-20-2009, 08:38 PM
hope one day i can go to japan and cruise with you guys
09-22-2009, 10:14 PM
been a while since you posted man
did you forget your Mosqiton login? lol car looks cool as hell What are the offsets -13 and -19 respectively? Are the rear arches RunFree overfender flares blended in or custom flared metal? Love how they match to the kit perfectly ![]() RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式 |
09-23-2009, 11:47 AM
Kid Karola Wrote:been a while since you posted manLOL! I already thought the hachi looked familiar! ![]() Maybe use the "I forgot my password" functionality? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
09-25-2009, 03:49 PM
yes I was MoSqiToN but got bored of that name so figured I'd change it. I wanted to keep the same name on other boards and I like this name better.
These days I have a little more time to check forums again so starting off fresh -- JailBait -- Bait me! |
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0169-1024.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/IMGP0005resized.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0073.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0080.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/IzuDrive-062.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/IzuDrive-067-1024.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/IzuDrive-094-1024.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/IzuDrive-104.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/IMGP0030.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0097.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0099.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0101.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0086.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0108.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/DSC_0157.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i203.photobucket.com/albums/aa64/unicorse/IMG_1268-web-722684.jpg)
![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](https://www.aeu86.org/sticker-banner-468.gif)
did you forget your Mosqiton login? lol car looks cool as hell ![AEU86 AE86 - My Revised '80's Thrashbox [Image: AEU86 AE86 - My Revised '80's Thrashbox]](http://i148.photobucket.com/albums/s15/karolex147/86LIFE.gif)
