My Drift project - 83' Trueno coupe
12-09-2010, 07:36 PM
Post: #141
Tank is done Big Grin Finished it today!
Made a circle from 4mm aluminium sheet to hold the pump cover and etc, and to be a suppor on the tank:
[Image: AEU86 AE86 - My Drift project - 83' Trueno coupe]
Also - from the same 4mm alu - made the top cover for the fuel pump / in-out lines:
Fuel pump braket on the cover, and out / return lines
Also - the same 4mm support circle for the fuel level sender:
Everything was pressure tested after all the weld where done - and there was only one small spot wich needed reweld Big Grin Next - i will have to make a swirl pot and all the mountings for the external Bosch pump Smile
Ex-owner of JDM 83' Trueno Coupe
DCw Classic, classic cars restoration,
JDM wheels & parts import, sales.
http://www.facebook.com/DogCustomWorks
+37067170000
12-09-2010, 08:08 PM
Post: #142
is very naish!
I like Thumbs up!
Philip
12-09-2010, 09:01 PM
Post: #143
can i order 1 or 2 tanks? Tongue Tongue
04-11-2011, 11:44 PM
Post: #144
More work has been going latly on this car Smile Found some time to do some fabrications - so here are update:
Done alot of small things that ussualy take bunch of time... Installed Adjustible Cam gears from HKS, redone Intercooler in and out pipes, radiator expansion tank / filler has been done, radioator it self has been rewelded / inlet outlet has been rewelded.
Oil filter relocation kit along with all the lines has been installed, turbo feed / return lines has been done and layed fuel lines over the interior.
Also - started manufacturing top mount pedals - not alot of done yet - but some sort of shape is visible (by the way - one thin pedal that is visible here - is trottle pedal - not the brake like some people think Big Grin)
Also - did all the steering column from 0... still not finished - but its taking shape already also Big Grin Had to re-do piece of the flor under the seat to make it sit as low as posible (im 1.97cm - so need some space Big Grin)
And FINALLY moved to my new garage with Lifters and lots of space - so everything now is 10x easyer!
+37067170000
04-11-2011, 11:45 PM
Post: #145
Finished with oil cooler. Had to reweld AN10 buns on it, fitted all the lines, and installed everything back finally. one job done Big Grin
+37067170000
04-11-2011, 11:51 PM
Post: #146
And finally started all the assembly, then parts go into the place not temporary Smile 'Hot' side of the motor has been assembled fully. All the lines now are connected, everything is wraped in Heatwrap where its needed.
On the ' cold' side of the motor also some works has been done. Filler tank has been mounted back into its place, radiator also has been mounted back to its place along with 2 fans under it.
And started to mock up all the plates around intercooler / radiator, and oil cooler. Tomorow will start building them from Aluminium.
More news soon Smile
+37067170000
04-12-2011, 02:05 AM
Post: #147
nice ride is that a external wastegate you got their ??? Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect! Respect!
04-12-2011, 08:22 AM
Post: #148
Lol, yes, thats the External WG...
+37067170000
04-12-2011, 09:35 AM
Post: #149
lol got one on mine to will up load a pick l8r its a fair bit different to yours Thumbs up! love the sound of it, will you up load youtube vids when its finished would like to here it
http://www.youtube.com/watch?v=K_Y5bez9bdk
how much bhp you looking at getting out of it [/youtube]
what gear box you got in her ???
04-12-2011, 11:04 AM
Post: #150
TURBO-AE86 Wrote:lol got one on mine to will up load a pick l8r its a fair bit different to yours Thumbs up! love the sound of it, will you up load youtube vids when its finished would like to here it
looking around 280-300hp mark. Will see what turbo can push out. Gearbox is from SXE10 Altezza 6 speed one.
+37067170000
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 17,669 10-07-2018 09:45 PM
  Trueno Coupe South Africa MIGGZFSU 151 126,210 06-07-2018 09:40 PM
Last Post: MIGGZFSU
  Scuderia rollator CE86 trueno project NoHachi 136 172,492 04-15-2013 05:53 PM
Last Post: [Walaki]D`Lair
  Ae86 Levin drift project. filip.alin 7 11,005 01-20-2013 03:05 PM
Last Post: filip.alin
  my slow trueno project cfly86 38 48,205 12-12-2012 04:35 AM
Last Post: cfly86
