My 86 GTS won't stay on.
04-08-2014, 02:36 AM
I bought a 86 corolla the other day and the car didn't start but it was cuz the fuel pump didn't get power so I put a toggle switch on it to give direct power now it works an turns on sounds great the motor is running strong but when I let it idle it dies slowly, sometimes it stays on but most of the time it dies. I can't figure out what the problem.
04-08-2014, 11:51 AM
Check the circuit open relay & efi main relay. Efi relay in the engine bay, & as far as I remember the circuit open relay is in the passenger compartment either next to the fuses or near the ecu...
04-08-2014, 12:13 PM
Check the ecu for error codes.
AFM or MAP engine ?
  Won´t start AlexKTM 6 20,291 12-04-2017 10:05 PM
  where to start on sr5-GTS swap dinkers542 0 4,430 12-20-2014 02:13 AM
Last Post: dinkers542
  anyone produce new harness for bluetop?gts driveshaft dinkers542 8 10,912 11-25-2014 09:18 PM
  3rd door support gas springs (stay) - worn out max_ae86 5 8,005 09-01-2013 03:20 PM
Last Post: Jezza_hr
  my bluetop 4a-ge won't start HELP Lykowsky 4 7,491 07-04-2013 10:00 PM
Last Post: Lykowsky
