Mux213 Levin GTS
04-19-2005, 01:48 PM
Post: #151
Mux213 Levin GTS
How does it sound mux? Too loud?
04-19-2005, 02:59 PM
Post: #152
Mux213 Levin GTS
Dorito,
It sounds pretty ok actually. Inside the car I dont notice any difference, outside the car you can hear this exhaust rattle a bit more, its a bit more raw sound, but it really isn't that different then my old 'exhaust'. Just looks a hole lot better ![]() I do get some more looks strangely enough, maybe at higher speed people driving next to me do get treated to more music from my exhaust ![]() Driving through a tunnel with the window open is the best though
04-19-2005, 06:05 PM
Post: #153
Mux213 Levin GTS
mux213 Wrote:All I need now are blue seatbelts (instead of the brown ones) How about black seatbelts? I have a set i the basement... :wink: Youtube Myspace and I´ll Google your Yahoo |
04-20-2005, 10:52 AM
Post: #154
Mux213 Levin GTS
mux213 Wrote:Driving through a tunnel with the window open is the best thoughSchiphol tunnel by any chance?
04-20-2005, 10:19 PM
Post: #155
Mux213 Levin GTS
knudsen,
remind me to put a picture up about what the MOT guys did to my seat belt to get the car through MOT.... Jon probably has some blue ones for me btw ![]() banpei, haven't tried that one yet actually...
04-20-2005, 11:00 PM
Post: #156
Mux213 Levin GTS
Mux, im now giving you a reminder, to put up a picture about what the MOT guys did to your seatbelt, to get the car through MOT...
07-02-2005, 01:12 AM
Post: #157
Mux213 Levin GTS
Hmmmm, I still need to post that seatbelt picture
![]() Anyways, tonight I finally found out whats wrong with my exhaust... Between the exhaust manifold and the 2-1 part, the exhaust was held together with just 1 bolt and nut! And that nut had started to come loose!! I could just move them appart from eachother! There is also no gasket between these two parts!! I would a second bolt and bolted it all back together, going to find a 3rd bolt and see if I can get a real gasket for it and that should solve my exhaust problems for the time being
07-02-2005, 10:49 AM
Post: #158
Mux213 Levin GTS
mux213 Wrote:There is also no gasket between these two parts!! I would a second bolt and bolted it all back together, going to find a 3rd bolt and see if I can get a real gasket for it and that should solve my exhaust problems for the time being Often there are 2 metalized rings instead of one gasket. Use studs instead of bolts and keep in mind that these parts heats !!! |
07-02-2005, 12:03 PM
Post: #159
Mux213 Levin GTS
Jamie,
yeah I am worried about that, I'm not sure where to get the best things to bolt it up. What I have now is just temporary, eventually I'll need to take the 2-1 part off and fix it correctly. Also first need to get those rings somewhere because I think they are missing... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
07-02-2005, 12:16 PM
Post: #160
Mux213 Levin GTS
mux213 Wrote:Jamie, There are AE86 with gasket and AE86 with rings - I seen the two types in Toyota parts diagram ! First chek yours. I bought full gasket set for 4AGE bigport - these rings were included (RIKEN brand, 35EUR value for full set). |
| Deaty's GTS Project | Deaty | 9 | 9,357 |
04-27-2021 06:10 AM Last Post: Deaty |
| 1985 Corolla GTS Project | mattscar | 5 | 13,255 |
01-30-2011 07:30 AM Last Post: mattscar |
| My SR5 to GTS Restoration Conversion. | Lofty | 15 | 26,318 |
09-25-2009 06:52 AM Last Post: Lofty |
| My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) | ryceboy_124 | 4 | 25,663 |
08-05-2009 04:25 PM Last Post: Eric |
| AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 102,561 |
03-16-2009 10:02 PM Last Post: banpei |
![AEU86 AE86 - Mux213 Levin GTS [Image: AEU86 AE86 - Mux213 Levin GTS]](https://www.aeu86.org/sticker-banner-468.gif)
