Mux213 Levin GTS
12-21-2006, 11:45 AM
Post: #371
Mux213 Levin GTS
Owh and I do not have adjustable panhard rod nor adjustable four links YET, I do want those but there are no ill effects noticable yet.. I haven't really checked the alignment though, I'm sure its off at the moment from left to right.
12-21-2006, 05:49 PM
Post: #372
Mux213 Levin GTS
Looks very nice.
I used the same springs but it didnt came down as much as your car. Weird ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. Toyota Corolla GT Twincam 1.6 16V (My new project )
12-21-2006, 06:46 PM
Post: #373
Mux213 Levin GTS
CircuitFreak Wrote:Looks very nice. NO! not weight reduction
12-21-2006, 08:00 PM
Post: #374
Mux213 Levin GTS
Owh right,
Sorry Rutger, I forgot to mention, there is indeed roughly 20kg of junk in the boot (tools and such) and like Jasper sais, you've got you're boot all stripped out. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
12-21-2006, 09:36 PM
Post: #375
Mux213 Levin GTS
Thx Mux! About lifting the car and the spring coming out: try ziptiting the springs, they defo won't come out from their place.
![]() If you want go cheap you can try relocating the shocks lower fitting on the axle. They should go "deeper" so the shocks will have much length to operate. I decided to cut one more ring from my springs because now I see that the "stock" suspension can operate lowered so much.
1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
12-21-2006, 09:41 PM
Post: #376
Mux213 Levin GTS
Zipties are not a solution likely to pass MOT inspection around here..
12-21-2006, 09:54 PM
Post: #377
Mux213 Levin GTS
TE71corolla Wrote:NO! not Mux213 Wrote:Owh right, Thats right i didnt think of that. I also removed the heavy gas tank. But yours looks way cooler.
12-21-2006, 11:59 PM
Post: #378
Mux213 Levin GTS
Nah I'm going 1cm more high, this is to low for me. Going to add a spacer...
As for the zipties, it'll just pull out the shocks from the top wouldn't it? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
12-22-2006, 12:37 AM
Post: #379
Mux213 Levin GTS
I don't really get what you mean with pulling out the shocks from the top.
the zipties are good for keeping the axle "close" to the chassis - as close as the springs full length allow. Don't letting the axle "fall down" until the shocks stop it. 1987 Toyota Corolla GT coupe - for holidays oversteer 2005 Toyota Corolla - for daily understeer |
12-22-2006, 12:45 AM
Post: #380
Mux213 Levin GTS
Sutter,
The springs aren't fixed to the body of the car nor are they fixed to the axle if you lift the car, they 'stick' to the body and come loose from the axle If you ziptie them to the axle they will stick to the axle, but come loose from the body. I dont see how you can ziptie it to the body without drilling holes into the body which I never like to do Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
| Deaty's GTS Project | Deaty | 9 | 9,579 |
04-27-2021 06:10 AM Last Post: Deaty |
| 1985 Corolla GTS Project | mattscar | 5 | 13,320 |
01-30-2011 07:30 AM Last Post: mattscar |
| My SR5 to GTS Restoration Conversion. | Lofty | 15 | 26,540 |
09-25-2009 06:52 AM Last Post: Lofty |
| My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) | ryceboy_124 | 4 | 25,734 |
08-05-2009 04:25 PM Last Post: Eric |
| AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 103,577 |
03-16-2009 10:02 PM Last Post: banpei |
![AEU86 AE86 - Mux213 Levin GTS [Image: AEU86 AE86 - Mux213 Levin GTS]](http://img186.imageshack.us/img186/2723/carb2ck1.jpg)
![AEU86 AE86 - Mux213 Levin GTS [Image: AEU86 AE86 - Mux213 Levin GTS]](http://www.driftparts.nl/Eric/Spaanbanaan.jpg)
