Mux213 Levin GTS
04-08-2006, 01:30 AM
Post: #241
Mux213 Levin GTS
What brand brake lines have you got Mux ?
Koukis - Red, Silver/Gray,
04-08-2006, 01:54 AM
Post: #242
Mux213 Levin GTS
@Mux, the trick is to start driving and racing a car you REALLY dislike...amazing what lengths you'll go through to save a buck then. Cool
04-08-2006, 08:27 AM
Post: #243
Mux213 Levin GTS
NoHachi, good point. I like spending money on this carSmile
DayTona, Uhm, I've got ZAXimonium Super Stainless Steel brake lines!Smile
Zax, what 'brand' of brake lines am I getting again?Smile
04-08-2006, 09:32 AM
Post: #244
Mux213 Levin GTS
Ivan141 Wrote:You could probably have gotten 4 discs and 4 sets of brakepads for about the same price or less from USN centuri.. But it really doesnt matter much. I paid about the same for the front discs and rear pads as the prices on that website, and that's without the usual discount..
Yeah, but do they also have a clutch-slave cylinder there? Tongue
Mux ordered one for me along: I'm definetely in need of replacing the old one. I forgot to check the clutchoil a few weeks and suddenly it was empty again. Confused
For the new slave cylinder: see the attached pic Smile
Anyway, to get back on topic:
WOW! Huh
It looks like you can put it on a recordplayer and listen to the music your hachi made. Big Grin
04-22-2006, 09:33 PM
Post: #245
Mux213 Levin GTS
Today proved to be a very interesting day. First I went to Grootebroek, my friend Ed was having a celebration because his DeLorean garage has joined forces with one of the biggest supplier of DeLorean parts in America.
For the occasion they had a dyno there to test the performance of the DeLoreans that came there. Later in the day they let other cars get a try aswell and offcourse I put the hachi to the test.
I am well pleased with the results. 112HP @ 6150rpm at the wheels measured. Calculated back with the measured drive train losses it came to 137HP at the flywheel give or take a bit. Not bad for a 23 year old stock 124HP engine with only the intake and exhaust changed.
Torque is 175Nm @ 4259 rpm but looking at the graph it has a jittery but pretty flat torque up to 5500 rpm so I am well pleased with thatSmile
In the afternoon I went to Jasper (TE71Corrola), unfortunately I had forgotten my camera. We put a rebuild caliper on the left rear, the others will be done later on. We also cleaned up my lights so they no longer look warn out and old and hooked up the blinkers at the side.
Last but not least my fiberglas front fenders came off and my old metal ones were put on. Jasper had cleaned them up for me and welded new bits of metal where rust used to be. It looks really good eventhough the fixed bit are now only covered with primer and I have holes where the old blinkers and antenna used to be.
What was most surprising however was that the old color of my car matches the new paint job EXACTLY! There isn't even the slightest difference in tint. Its amazing that a brand new paint job matches a 23 year old original paint job so well. It opens up a few avenues I haven't thought about for awhileSmile
04-23-2006, 03:14 AM
Post: #246
Mux213 Levin GTS
Mux, i really must say: Sorry dude, there MUST be a fail in that dyno-test. Not only is the hp output the highest i have ever seen in a stock 4age, but the momentum of the engine is WAY to high to be realistic.
Furthermore; You have your max hp at a pretty low rpm, all others have max @ 500-700 rpm higher. Evenmore the max torque is at roughly 1000 rpm lower than usual.
Either your engine is a "special jubilee limited edition" (YaY then) or theres a guy with a dyno in need of calibration.
04-23-2006, 08:35 AM
Post: #247
Mux213 Levin GTS
Knudsen,
Hehehe, well maybe the dyno was thrown off after having measured so many heavy DeLoreansSmile
I'm probably going to have it dyno tested at a mates garage some day in the near future. Then we will see what the difference is. Smile
04-23-2006, 10:00 AM
Post: #248
Mux213 Levin GTS
Don't you understand anything Mux...this is the time where you should start screaming that the dyno operator is knowledgable and that there is ABSOLUTELY NOTHING WRONG with the dyno etc..ghe ghe ghe. Such seems to be the tradition when it comes to plots.
Tongue
04-23-2006, 03:52 PM
Post: #249
Mux213 Levin GTS
seems like you have a nice healthy engine ther mux. Thumbs up! seems a bit high tho.
Btw; what kind of suspension do you have under your hachi?
04-23-2006, 06:04 PM
Post: #250
Mux213 Levin GTS
Just a stupid question: are these UK or German horses? Dumb question
Lightbulb Deaty's GTS Project Deaty 9 9,369 04-27-2021 06:10 AM
Last Post: Deaty
  1985 Corolla GTS Project mattscar 5 13,259 01-30-2011 07:30 AM
Last Post: mattscar
  My SR5 to GTS Restoration Conversion. Lofty 15 26,334 09-25-2009 06:52 AM
Last Post: Lofty
  My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) ryceboy_124 4 25,666 08-05-2009 04:25 PM
Last Post: Eric
  AE86 Trueno Coupe (SR5-GTS)//Sweden Allexz 71 102,640 03-16-2009 10:02 PM
