More 4ac problems
07-18-2007, 07:47 PM
More 4ac problems
They seem to be never ending. I finally got the timing belt back on, and everything in place, tried to do the timing, and my hachi still runs like absolute junk. I KNOW it had more power before I replaced the timing belt. The distributor is all the way against the firewall, and I still can't get it factory timing (5 btdc) it will go to tdc, but thats it. Could my distributor be a tooth off? or could my timing belt be a tooth off? any help guys?
1971 Ford Mustang 1984 Hachi-Roku http://www.club4ac.com slowest AE86 club on the net
09-09-2007, 06:07 PM
More 4ac problems
I just re-checked my timing and valve clearances on my 4ac yesterday. if you have a 4ac, the factory timing should be set at 10 degrees BTDC. If it's at 5 degrees BTDC, it should run like crap. Also, make sure you set your idle speed to 800 rpms + or - 50 rpms before you adjust the timing.
another thing i noticed, there seems to be 2 timing marks on my belt, but there should be only one mark that'll line up with the markings near the crank pully (i.e. 20 15 10 5 0 5) when adjusting with the timing light. |
09-11-2007, 09:37 AM
More 4ac problems
surfingdrums Wrote:Could my distributor be a tooth off? or could my timing belt be a tooth off? any help guys?For the first the answer is NO, but for the second question the answer is , Yes it could. You have to make sure that the marks on the cam gears are totally looking to each other. And there is a mark on the Block too, which must be looking to that on the pulley. But, what is exactly the problem? The engine is just sort o power, or it is working rough too?
| Big wheel problems | gh0st | 16 | 14,000 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,486 |
| Problems Mintex M1155 pads | Dino86 | 9 | 12,203 |
07-04-2017 11:22 AM Last Post: totta Crolla |
| 4ac gearbox on 4age | hachirokkos | 2 | 8,132 |
05-24-2016 10:16 PM Last Post: banpei |
| 16v Bigport fuel problems | Rascal21 | 1 | 6,137 |
07-04-2015 01:00 AM Last Post: jondee86 |
![AEU86 AE86 - More 4ac problems [Image: AEU86 AE86 - More 4ac problems]](http://img159.imageshack.us/img159/9409/39563944fwdsucksue7.jpg)
