Mintex brake pads installation
02-26-2007, 01:47 AM
what are squeel plates?
02-26-2007, 03:08 AM
Thank you, Apolan, now i don't feel that stupid for not knowing myself.
SQUEAL PLATES
Metal plates which are placed on the brake pads which are designed to audibly squeal when the brakes are almost fully worn.
according to http://www.std.com.au...
02-26-2007, 09:52 AM
domi,
then I feel even more stupid because the things I was talking about are the small little metal thingies that 'guide' the brake pad from the sides. No idea what to call them then Big Grin
Abe, should be possible to get the from Toyota. I'm not 100% sure if the additional sanding was enough to do the trick or whether its really that I left out these little brackets.
Can someone look up parts numbers for these, I need to get a working EPGBig Grin
02-26-2007, 11:04 AM
ah so thats them litlle metal pieces that provide a snuggle fit of the pad in the caliper?
02-26-2007, 02:34 PM
Apolan Wrote:ah so thats them litlle metal pieces that provide a snuggle fit of the pad in the caliper?
YupBig Grin
02-26-2007, 03:15 PM
I thought it was the rubber stickers that came with the pads! Respect!
[Image: AEU86 AE86 - Mintex brake pads installation]
Cump“s
Filipe Oliveira
02-26-2007, 08:22 PM
lipinhu, yeah those were interestingBig Grin I stuck um on, not 100% sure what their purpose is, possibly the same as the squeel plates domi mentioned
02-26-2007, 08:36 PM
http://www.so-calspeedshop.com/downloads...Manual.pdf
This one has a schematic of everything in a brake kit, if I understand what you mean - it is referred in there as pad-calipers. Which sounds stupid as it would then be easily mistaken for the brake caliper itself, the one with the cylinders and all, but oh well - english has been known to suck here and there =)
02-27-2007, 12:03 AM
You have squeel plates..little metal clips that come in contact with the disc when the pads are worn..causing a loud squeel so you'll know to replace your brakes, but the ones mux meant are the anti-squeel plates. They make installing pads on my rear calipers nigh-impossible so I only used half of them, without any squeel issues. The rubber pads on the back perform the same function as copper-grease applied to the back of the pads...preventing squeel.
02-27-2007, 12:13 AM
well guys i am a little confused with all these things you are saying here ...
Please make a DIY wizzard for installing the pads so we 'll manage to have the best results!
Thanks Respect!
  Problems Mintex M1155 pads Dino86 9 11,586 07-04-2017 11:22 AM
Last Post: totta Crolla
  Brake PADS:) Mux213 32 50,530 11-08-2016 04:55 PM
Last Post: pack
  Mintex brake pad MDB1193 Dino86 9 11,208 02-27-2014 11:26 PM
Last Post: Dino86
  Brake Pads |BUDA| 8 12,269 04-16-2013 08:30 PM
Last Post: damusto
  Brake master cylinder for FC3S brake conversion Hachi Go 8 16,760 03-03-2011 12:06 AM
Last Post: filh
