Mine
09-10-2007, 10:16 AM
Post: #91
Mine
robokill Wrote:why didn't you coat the full underbody ???? like the spare wheel arch etc
There is plenty of Toyota underseal on the area's i've not painted so i couldn't see there being much point.
banpei Wrote:You're painting it yellow again? Tongue
Yeah, i figured it will be different and get some attention.
I did a photoshop of one in yellow over black and it does look well Thumbs up!
Building an AE86 from a pile of rust!
Here she is !
09-21-2007, 01:30 AM
Post: #92
Mine
A few more pictures..
[Image: AEU86 AE86 - Mine]
[Image: AEU86 AE86 - Mine][/QUOTE]
Here she is !
09-21-2007, 07:30 AM
Post: #93
Mine
Sweet! You even painted the inside. Thumbs up!
This is going to be a very nice rebuid! Smile
09-21-2007, 08:24 AM
Post: #94
Mine
will it be a racecar or just a daily ?
09-21-2007, 09:09 AM
Post: #95
Mine
robokill Wrote:will it be a racecar or just a daily ?
I intend to drift it but keep it so i can use it, as you can see the heater has gone back in and the carpet will be upto the back of the seats.
With the power i'm hoping to have on tap a few kg's isn't going to make a lot of difference Thumbs up!
Here she is !
10-02-2007, 09:10 PM
Post: #96
Mine
Had a day off today so made a bit of progress and found some problems ...
Fidanza 212mm Flywheel and Helix clutch..
Inlet manifold fitted and water pipes etc
What happened next...
She's in Big Grin
Need to shift the washer bottle before it dribbles down the inner wing as a blob of plastic ... Plus the wiring will have to be re-rooted, in-car all being well and bring it out further to the drivers side
Plenty of room at the front, even with a electric fan there should be enough room to V-mount but can't afford an intercooler to suit... A mod i will consider later..
Lots of flywheel showing Huh
Last but not least i need to make the hole for the gear stick it little bit longer, but that won't take long.. Big Grin
Here she is !
10-21-2007, 10:18 PM
Post: #97
Mine
Sweeps
I'm currently in the process of seam welding my AE86 and was wondering if you have the dimensions of the gussets you have welded to your car? I would like to make some for my build.
Thanks
Ian.
10-23-2007, 06:39 PM
Post: #98
Mine
Nice progress there, I would consider refitting the shielding between the engine and the gearbox though.. A lot of crap can bounce right into your fleewheel, possibly cause some damage along the way. Even a home-made shield-plate would suffice, as long as it keeps rocks out.
11-01-2007, 03:35 PM
Post: #99
Mine
*ian_pez* Wrote:Sweeps
Thanks
Ian.
I've got to be honest Ian and say no, i made them to fit the car, its not a perfect square shape in the corner so it took a few attempts to get them right, the use of a grinder came in very handy.
Ivan141 Wrote:Nice progress there, I would consider refitting the shielding between the engine and the gearbox though.. A lot of crap can bounce right into your fleewheel, possibly cause some damage along the way. Even a home-made shield-plate would suffice, as long as it keeps rocks out.
Funny you should say that Ivan as i had a few people say the same, so :
Gearbox removed and plate replaced as suggested.
Gearbox mount made to be able to use Supra mount.
Front Calipers sand blasted, painted, new seals/rubbers etc.
EVO 4/5/6 coil packs fitted. Alloy plate to keep everything in situ, studs fitted to rocker covers, thread locked and lock nuts, nyloc nuts to hold plate in place.
Job sorted.
Most of wiring has gone, only the basics remain like water temp, starter motor wires, alternator. This will all be rerooted under the dash with minimal wiring under the bonnet.
Here she is !
11-29-2007, 03:49 PM
Post: #100
Mine
With the liitle time i've had lately i've made slow progress.
But never the less, anything done is one job less..
I will be making a gaurd to protect the filter :nod:
Here she is !
  Mine AE86 from up norht corolla4agze 19 30,797 10-24-2012 10:24 AM
Last Post: corolla4agze
