Mine AE86 from up norht
09-19-2010, 07:48 PM
Did get some work whit car.
enginebay in paint, Just need wet sand and onelayer paint more to be ok.
Some holes i did weld off.. rear suspension "rustwork" i deside to work also. Just origin stuff off and make all new.. 3-4cm bigger radius on shocks on rear..
[Image: AEU86 AE86 - Mine AE86 from up norht]
The panda coloring is mine goal or just "super white"
12-06-2010, 09:31 PM
Long time gone, test fit the hiace rear end to car, and +4 et 7x15" wheels nice fit. still could be little more wider.. custom driveshaf from friend and 4.3 whit lsd to rear end...
did think about brakes, mk3 supras rear breaks or just s13 nissans bigger disk and regular ae86 calibers or similar set..
03-25-2011, 10:39 PM
5days work ahead and then 2 weeks mine corolla. Cant wait to get rest of bodywork done and maybe painting engine-bay again. But need to get new pictures when get pack home.
03-26-2011, 12:11 AM
will you keep the wide body look or?
Do you like the trueno front ?
07-13-2012, 09:41 PM
i am keeping the widebody, but put cby Flares and levin front end
08-23-2012, 02:53 AM
looking good..
08-23-2012, 08:52 AM
i think one "winter works" to do get road use condition. And still some parts are missing. Lot work done after those pictures. Must put some new images when i get some free time to do it.
But next summer its on road mayby on winter if lot of spare time to work on it.
09-17-2012, 11:09 AM
Had some work done to car. genuine trunk "door" had some un wanted holes on it. Weld them up then some tin and looks ok. "cby" flares needs some work to get them fit nice and only rust work left is in rear suspeonsion towers and few minor work. Then i get to last underbody welds grind and some sandblasting to them and paint stuff..
The LHD side door hinges are quite bad condition need find better/new..
Mayby need some new photo some day.
10-24-2012, 10:24 AM
My adapter between 7a block and j160 trans ready. quite tide fit to get under car but there it goes.
  Mine Sweeps 107 125,193 12-04-2007 04:19 PM
Last Post: jamiemirror
