Mikzu's 4A-GZE project
08-19-2008, 06:46 AM
You will find the the sensor block at the back of the head will be very close to the firewall. If thats the final position for the coil packs you could replace the sensor block with one from an AE86 or AE82 one which is alot slimmer.
What gearbox are you going to be using? ![]() Corolla Levin SR 1984 AE-85 (Project car) Corolla Runx Z 2002 (Runabout) |
08-19-2008, 08:14 AM
Mikzu IV Wrote:4agze Wrote:nice but whats up with the pink valve color so it should be looking like this? ![]() man, get a new camera
08-19-2008, 09:03 AM
use less saturation
08-19-2008, 10:54 AM
PetzK Wrote:Mikzu IV Wrote:4agze Wrote:nice but whats up with the pink valve color Awwwww man, i thought pink was sooooo damn sexeh!!!! Much hotter than this common red look tbh
08-19-2008, 07:30 PM
4agze Wrote:Mikzu IV Wrote:Nono. it's a real gze from ae101, and I payed around 1200e for it. LoL. I think I'm going for a small fmic, later. but now just with nothing not even the original cause it's damaged Rick Wrote:You will find the the sensor block at the back of the head will be very close to the firewall. If thats the final position for the coil packs you could replace the sensor block with one from an AE86 or AE82 one which is alot slimmer. thanks for the advice, I was wondering if it's going to hit the firewall, I hope my ae86 sensor block had 2 sensor places... the gearbox will remain t50, but if it breaks I will go for the w55. thanks petzk, you did it, but it's not really that red 280z '75 audi S4 B5 '99 KE25 '71 |
08-20-2008, 02:38 AM
as long as you dont mount your IC pipes like this youll be fine
![]() ![]() if you want a cheap and good IC use the 7mgte stock IC ![]() here is my 4agze 4 years ago
08-20-2008, 09:13 PM
4agze Wrote:as long as you dont mount your IC pipes like this youll be fine Awesome, I really like how it's done in the 2nd picture. here's what I did to my ae101 ecu as it had no 22 pin connector plug, 101ecu -> 86 connector -sta to ?? -a/c nc -sp1 to sp -til to -frp to ?? -w to W, check engine -els1 to bat? -egw nc -els2 to ?? idle up diode what is that? -batt to bat -cco nc -fc to fc -+b1 to +b1 -+b to +b
08-21-2008, 06:45 AM
11-01-2008, 07:39 PM
Little update,
I received some parts that were missing, but from a 7mgte supra -Igniter 89620-14440 -two resistor packs one for fuel pump and one for injectors I thought that the supra igniter should work in gze just by re-pinning the igniter's connectors, to mach the gze igniter's connectors wire colors and leave the green and beige not connected ![]() left gze igniter connector, center the 7m repinned, right repinned gze next step is to wire-up the injectors resister pack does anyone have an idea? the wires on my pack are 3x brown and 1x white the wires on my gze harness are 1x black and 2x black/orange It might also be that all this doesn't work 280z '75 audi S4 B5 '99 KE25 '71 |
11-02-2008, 06:27 PM
Hi! Could you help me a little with ignitor connection? I have GZE ignitor but i have to wire it from ecu and on the web there are not enought info about those wires. There are those 2 connectors on the ignitor, and as far i know, smaller 2 wire connector are outputs for coils, black for coil 1,4 and blue for coil 2,3, if i am right...
But the bigger, with 5 wires are totally blank for me. In all wiring diagrams they show only three wires going to it, and the colors arent same on the ignitor side. I have colors on the upper row, left to right: brown, grey, red. Under: yellow, white. Could you tell me what are colors (and meanings if you know) on the engine wiring loom whitch connects those colors? |
| Mikzu IV ae86 from Luxemburg+ shuttle + ke25 + 280z + chaser | Mikzu IV | 151 | 218,628 |
06-21-2012 08:05 PM Last Post: bozu |
| Corolla GT-Z twin cam 16 (4A-GZE) | danielvanderwoude | 24 | 32,943 |
10-05-2010 08:18 PM Last Post: robokill |
| Opex: AE85 3a-gze>>3a-gzte in progress | opex | 24 | 41,506 |
01-14-2010 06:09 AM Last Post: opex |
![AEU86 AE86 - Mikzu's 4A-GZE project [Image: AEU86 AE86 - Mikzu's 4A-GZE project]](http://img39.imageshack.us/img39/4898/profilepick.jpg)
![AEU86 AE86 - Mikzu's 4A-GZE project [Image: AEU86 AE86 - Mikzu's 4A-GZE project]](http://sites.internet.lu/folders/de_petz/dscn2712[1].jpg)
![AEU86 AE86 - Mikzu's 4A-GZE project [Image: AEU86 AE86 - Mikzu's 4A-GZE project]](http://i223.photobucket.com/albums/dd98/narcisomelvin/4agze.jpg)
![AEU86 AE86 - Mikzu's 4A-GZE project [Image: AEU86 AE86 - Mikzu's 4A-GZE project]](http://i223.photobucket.com/albums/dd98/narcisomelvin/munky7.jpg)
![AEU86 AE86 - Mikzu's 4A-GZE project [Image: AEU86 AE86 - Mikzu's 4A-GZE project]](http://i223.photobucket.com/albums/dd98/narcisomelvin/IMG_1789.jpg)
![AEU86 AE86 - Mikzu's 4A-GZE project [Image: AEU86 AE86 - Mikzu's 4A-GZE project]](http://i73.servimg.com/u/f73/11/53/39/78/12458710.jpg)
