Map Car Starting Issues
09-09-2007, 07:21 AM
I got a new map harness from europe and got it installed. I went to go start the car and it cranks but it doesnt even try to start. I checked spark and it has spark and the fuel pump is running. Then I tried my powerfc and it says theres a duty cycle but the ignition stays static. I tried a different distributor with the same result. Could use some advice.
- Fuzzy |
09-09-2007, 07:45 AM
What engine ?? What car ?? What loom ??
MAP sensored 16 valve 4AGE engines have a cold start injector that squirts enough gas during cranking to fire the engine. But it will die when you let go of the key if the main injectors are not firing. AFAIK MAP sensored 20 valve engines just fire the main injectors a bit longer during cranking to richen the mixture. Check you have 12 volts supply to the injectors when the ignition is ON. The ECU pulls 12 volts to earth to fire the injector. Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
09-09-2007, 11:43 PM
Yeah i found it I forgot to connect the yellow injector wire to the run power position, doh!
- Fuzzy |
| map sensor cheating? | fdsjakl890 | 8 | 4,308 |
08-26-2025 01:12 PM Last Post: Ivan141 |
| Running issues | sam3007 | 6 | 6,194 |
| AFM to Map Conversion | ps13michi | 3 | 6,663 |
| lntermittent starting | totta Crolla | 6 | 7,103 |
08-31-2021 06:21 PM Last Post: totta Crolla |
| Starting problems 4-AGE kouki | Hanzo | 3 | 5,279 |
