Manual steering conversion query
07-12-2008, 06:49 PM
I've taken out my power steering set up and replaced it with a manual one.
Everything fine apart from one bit - connecting the steering rack to the steering column.
The shaft from the steering wheel is about 7-8cm too short to reach the rack Reason is the power steering joint is quite a bit higher as it sits on a resorvoir for the power steering fluid, so is actually closer to the steering column.
I guess they are different parts, and assuming I'm going to struggle to find the manual steering bar bit, what else can I do to fix it together? Surely someone else must have come across this problem
Thanks
07-12-2008, 10:46 PM
IIRC speak to Paz, he has got around this with a bodge? Ideally track the joint down, its longer than the PS version.
Also maybe speak to Big Yin he has a tonne of spares and might have ne kicking about?
[Image: AEU86 AE86 - Manual steering conversion query]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
07-13-2008, 01:16 AM
Thanks for reply,
Just found a pic of what Paz has done.
Also it seems a mk3 supra has the part that will fit too, which should be easier to find then a manual ae86.
will give Big Yin a PM too. Thumbs up!
07-17-2008, 01:53 AM
Yeah the T3 spacers really help for extra lock.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
07-17-2008, 02:00 AM
What you're looking for:
MKIII supra intermediate shaft.
MKI mr-2 manual rack u-joint.
Andrew
  Looking for jdm spec body repair manual AE111 0 1,064 10-08-2025 10:33 AM
Last Post: AE111
  20v Blacktop conversion.... Mylesmck 0 1,896 04-29-2024 05:48 PM
Last Post: Mylesmck
  Kouki to Zenki Levin grill conversion? Mylesmck 6 6,157 02-08-2024 10:30 AM
Last Post: r.ave
  Wanted: 3-rib engine repair manual Ivan141 6 5,513 09-09-2022 07:46 PM
  AFM to Map Conversion ps13michi 3 6,291 01-06-2022 10:34 AM
Last Post: ps13michi
