Manifold Vacuum on 16V with ITB's...
04-11-2010, 10:22 PM
On my 16V smallport I have Silvertop ITB's mounted on a custom
fabricated tube manifold. Vacuum is sampled from all four inlet tubes by way of small bore hoses (same size as OEM MAP sensor hoses). At idle I am only getting 30 kPa of vacuum (70 kPa absolute pressure). This seems a bit low, so has anyone got ITB idle vacuum readings to compare ?? I'm going to check the reading from the brake booster connection, as that comes from a larger set of manifold tappings. Just to make sure the small hoses, to and from the map sensor vacuum tank, are not causing a restriction. Cheers... jondee86 |
04-11-2010, 11:30 PM
I have ST ITB's with T3 intake manifold and 68/70 kPa absolute pressure at idle.
I'm using Megasquirt with Alpha-n because under load pressure drop near to 100 kPa Here's a video how idle http://www.youtube.com/watch?v=aTmtrCVMm8c and normal driving http://www.youtube.com/watch?v=7v6eSI1G898 |
04-12-2010, 03:05 AM
Interesting !! I knew that ITB's didn't have much vacuum, and it's nice
to know that someone else has about the same result. I'm running on a TPS only fuel map at the moment, but I would like to be able to get some sort of manifold pressure fuel map working, so I can run try out a TPS x MAP blend. That way I can use the Predictive MAP throttle pump feature on my Adaptronic ![]() Your engine looks very tidy... wish I had space to use that style of filter. Cheers... jondee86 |
04-12-2010, 07:43 AM
can you give me the tps only map ? i am going to setup a greddy e-manage ultimate with itbs too ... :wink:
AE86 FANATIC!!! |
04-12-2010, 10:15 AM
alimonos Wrote:can you give me the tps only map ? i am going to setup a greddy The map I have is just some line values I put in to make a startup map. It was set up for VE tuning, with the first line 35%VE @ 0% TPS, rising incrementally to 90%VE @ 65% TPS. Everything above 65% TPS is @ 90%VE, and all lines have the same value from 0 to 8000 rpm. The engine runs on this map with good A/F ratios, but I haven't tuned the idle properly yet. The self-tune function has completed a few cells, and they are not far off the numbers I started with. I really don't think the map would be of any help with what you are trying to do. Better for you to use a WBO2 gauge and adjust your settings until you get a good A/F ratio. Cheers... jondee86 |
04-12-2010, 03:13 PM
jondee86 Wrote:... This one it's a bit smaller |
04-15-2010, 10:57 AM
Looks as so I have a cam timing problem
around a bit, and now I have 45 kPa of vacuum. I'm going to degree the cams and then try a few different settings. I'd be happy if I could get around 55-60 kPa at idle ![]() Cheers... jondee86 |
| Smallport inlet manifold | totta Crolla | 6 | 5,563 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| How to install 20V ITB on 16V head | Mr.komp | 7 | 14,941 |
12-28-2015 05:35 PM Last Post: pack |
| US-spec vacuum hard lines | LordTD | 2 | 6,576 |
04-27-2015 07:18 PM Last Post: Project D |
| 4age blue top from MR2 same intake manifold? | dinkers542 | 8 | 13,535 |
11-02-2014 05:24 PM Last Post: ditn |
| VALVE ASSY, VACUUM SWITCHING, what's this for ? | Uzelac | 10 | 18,983 |
11-22-2013 10:40 PM Last Post: jondee86 |
