MCNSPORT.com SuperTune N2 (The re-build)
02-08-2009, 01:50 AM
Hi all,
We want to share this with you guys.. as you people love the AE86 as much as we do - ..and when it comes to AE86's, they don't come any better than the ultimate: AE86 N2
This is our N2...
We started off building this for an event in 2007, we used it for a couple of events and then parked it up in the corner of the MCNSPORT shop.
Now it's back........... We are going to use the MCNSPORT N2 in this year Irish ProDrift Championship with Darren "D-MAC" McNamara behind the wheel.
This is how it started out:
These picture were taken on tueday july 17, 2007 - We finished the car 11days later!
We started off wit a ex N2 ae86 built by suzukijidosya in japan
BHP: unknown
Weight: 885kg
[Image: AEU86 AE86 - MCNSPORT.com SuperTune N2 (The re-build)]
Work began that evening and we tore the car apart and called it a nite at 5am. the car was quick but as wit all 4ages produced little torque so weight loss was top of our list and im proud to say we have produced the lightest ae86 ever (until the next 1Smile)
We welded in a new sheet of steel in the rear and modded the wheel arch where the fuel filler once was
We removed the front panel for better air flow to the carbs
We rewired all the dash and moved the gauges from the centre console to in front of the driver
Rear fibreglass hatch: we removed the inner skin to save weight, the doors also got this treatment. in fact all panels on the car are fibreglass, we even moulded panels that we didnt already hav, bonnet, headlight covers, doors and rear hatch all in a 10 day period. lexan was used to replace the rear glass and side windows
bhp: 160-170BHP
weight: 710kg
spec:
Engine:
IN304 EX288 high lift camshafts / TRD valve springs / TRD head gasket & head 0.5mm shaved / ported & polished / Light weight AE92 pistons / Light weight gudgeon pins / TRD rod bearing / TRD Crank bearing / Lightened flywheel 3.7kgs / TRD engine mount / TRD transmission mount / OBR45mm carburetors / full transistor distributor
Transmission:
D-speed metal clutch / Cusco lsd
suspension:
TRD shock absorbers / mcnsport springs / cusco top mounts / mcnsport inner tie rods / ueo outer tie rods / cusco rca's / TRD and powerflex bushes
body:
mcnsport fibreglass trueno front fenders (alo available for levin) / mcnsport fibreglass trueno bonnet / mcnsport fibreglass trueno headlight covers / mcnsport fibreglass doors / mcnsport fibreglass rear hatch / mcnsport fibreglass rear quarter / Origin front bumper / vertex style rear bumper and sideskirts / TRD rear wing / lexan glass
wheels:
work meister s1
That was then, this is now.... 2009, we have now spent a few days in between other projects on the MCNSPORT SuperTune N2 rebuild.
On this new version we are going to be using a few new products:
new TRD bearings mains and big ends
new TRD headgasket
New cam gears
timing belt and tensioner
Front:
KW bump and rebound adjustable coilovers
KW 8kg springs
Tein camber tops
T3 RCA's
Power steering knuckles
Nagisa auto (ueo style) front lower arms
Nagisa auto (ueo style) outer tie rods
Nagisa auto (ueo style) inner tie rods
Tein tension rods
Whiteline anti roll bar
Black diamond disks
Mintex pads
Rear:
TRD shortstroke adjustable shocks
MCNSPORT 5kg springs
Nagisa auto 4 link
Sp-tec panhard rod
First pair of MCNSPORT carbon doors
Martelius R1 Exhaust manifold
Martelius 2.5inch "MCNSPORT Special" stainless steel under axle exhaust system
AE86 4AGE 20mm lower engine mounts
13x8 lighweight wheels
MCNSPORT Carbon Dash
Engine turned out to be in very good condition. Here's the head disassembled with various other bits including toda 304 and 288 cams. Pistons, Rods and Crank all inspected and are perfect so good news all round
Chassis leg we pretty bent from a previous incident so we pulled it. Its 90%
there will have it finished in the morn so more pics tomorrow. note some suspension parts fitted already pics of them tomorrow too
Engine stripped and cleaned for painting:
Front and rear suspension fitted:
Gearbox cleaned and painted:
Chassis leg straightened
Stickers removed, this is how she sits at the moment
FIRST START!!!
Here's a video from Darren's phone, featuring our mechanic Stephen (his first time on the internet!).
THE POOR NOISE IS DUE TO 4 OPEN PRIMARY PIPES, AS THE 2 into 1 SECTIONS HAVEN'T BEEN INSTALLED YET.. Smile
Peden & Darren - MCNSPORT.com
02-08-2009, 01:58 AM
you spent all that work and didnt even bother removing the entire roof liner? why?
Wow, I could have sworn I had an account here... I guess I'm the new guy Sad
02-08-2009, 02:02 AM
dazed_driver Wrote:you spent all that work and didnt even bother removing the entire roof liner? why?
The car was originally built in 11days to make an event...... so other jobs took preference, however rest assured, the roof liner is well and truly gone now Smile
MCNSPORT.com
02-12-2009, 01:04 AM
First MCNSPORT Carbon dash installed
Defi Gauges and control unit installed
02-12-2009, 05:44 PM
looks already like a number 1 car!
Gtsi-R
"Trust me, I was an engineer"
02-12-2009, 06:36 PM
Gtsi-R Wrote:looks already like a number 1 car!
Thanks dude, finally we get to work on one of our own AE86's for a change!! Smile
We'll keep you updated, MORE new Carbon pics for you soon..
MCNSPORT.com
02-12-2009, 07:24 PM
the wheels Yummie! Yummie!
02-12-2009, 07:43 PM
Eric Wrote:[Image: AEU86 AE86 - MCNSPORT.com SuperTune N2 (The re-build)]
They are just spare wheels from our MCN-Falken SR86.
WAIT TILL YOU SEE THE NEW WHEELS FOR THIS CAR...............................................
MCNSPORT.com
02-12-2009, 09:36 PM
Hurray! Thumbs up! Respect! Respect! Respect!
02-12-2009, 10:26 PM
what kind of shocks are those.
  (Catching up...) OST-085: 7AG Big Valve build w/Cat Cams 262 9.0mm lift cams oldeskewltoy 5 4,889 09-09-2022 09:07 PM
Last Post: Vaptor
  OST-050 - a VERY special build oldeskewltoy 49 45,787 01-05-2019 07:03 PM
  d3nso's little AE86 N2 build d3nso 27 40,909 11-13-2017 11:42 AM
  Beams Levin build mannix20vt 5 11,168 01-27-2016 12:39 AM
Last Post: mannix20vt
  Drift missile build [FIN] TuGeTu 7 22,817 11-09-2015 06:13 PM
