Lucky today
05-02-2011, 03:45 PM
Lucky today
I think anyway.
Went to start the car and it did'nt start first time, second attempt it turned over and then made a horrible noise from the engine.
After a little investigation I discovered that the cam belt tensioner spring had come adrift and pierced the cambelt, it was trying to rotate with the belt Smile Huh
The belt was very loose and had jumped a couple of teeth, I expected that but I had not expected the small stud that the tensioner pivots on to have come out completely.
Anyone care to suggest a series of events for what happened here ?
Lucky ? Just a new belt and spring needed.
05-02-2011, 06:22 PM
Lucky today
Pretty close call!!!Huh
Had a similar thing a few weeks back. I had ingintion problems and took the covers of to see if the marks line up like they are supposed to. I found that my spring was loose, too! Just waiting to rip my cambelt into pieces.
I was very lucky, too.
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
05-02-2011, 07:53 PM
Lucky today
Ah so it's no an isolated case then.
I shall be keeping a very close eye on it in the future.
What did you do with yours, new spring ?
05-02-2011, 09:21 PM
Lucky today
if you're running a stock 4age, nothing bad would have happened anyway.
05-02-2011, 10:04 PM
Lucky today
totta Crolla Wrote:Ah so it's no an isolated case then.
I´d put in a new spring if my head was stock, usually change it with every belt.
But I´d say it is an isolated case, cause I´ve got a massive skimmed head (talking about mm taken off by previous owner) Banging head
I allways had to tighten the belt by hand to get decent tension, so I just ditched the spring.
05-02-2011, 11:06 PM
Lucky today
Now there's a plan, I'm gonna ditch that spring too Thumbs up!
  I am going to change today spark's and coolant need help Ryo 8 9,711 06-25-2006 11:38 PM
Last Post: PazzaAE86
  Car died on me today, RIP fuelpump? Ivan141 12 15,057 11-21-2005 11:54 AM
