Lets play "Guess that sound!" aka diff problems
08-27-2010, 04:07 PM
Theres so much ratlle coming from the back Confused I need to set those brake pad springs properly, so there is also alittle disc squeeling. Today a new exhaust has been made. quite a good job bi i think its hitting the trailing arm mount on the rear axle..
Any familiar sounds guys?
08-27-2010, 04:31 PM
Im hearing the sound that is similar to sticking a cardboard in the spokes of a bicycle and riding it.
Sounds like a Chipped pinion or CW tooth.
Stop driving it.
08-27-2010, 05:21 PM
Thanks for your input, it might indeed be that. The car is driven only to get it from shop to shop, fixing things up for MOT. I was planning to deal with the diff later, hope this isnt so bad:/
Man in the end i will need to replace every f. thing on this car Undecided
08-27-2010, 09:48 PM
I think it must be worn out / burned diff bearing. that tone of voice isn't belongs to the cwp.
08-27-2010, 10:31 PM
http://www.bilgalleri.dk/vid_vis.aspx?VideoID=34214 my buddys ae86, almost evry tooth on cwp was gone..
08-28-2010, 01:19 AM
wow it isnt quite as bad as that, but something is up for sure. i get the worst noises if i gently tap the throttle at very low speed. like trying to bob the car forward..
  Big wheel problems gh0st 16 12,289 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 4,036 08-31-2021 06:20 PM
Last Post: totta Crolla
  Play between steering column and intermediate shaft after manual rack sonversion DaLanZhu 5 9,039 07-31-2019 11:28 AM
  Lets talk engine mounts kazi 6 9,603 08-31-2017 12:46 PM
Last Post: parrot
  Problems Mintex M1155 pads Dino86 9 11,236 07-04-2017 11:22 AM
