Kristian from Sweden
09-13-2004, 10:07 PM
Hmmm
Now I need to go steal the shocks of my mate that just bought a 325SmileSmile j/k
09-14-2004, 12:25 AM
BTW, could you tell me some more about the lexan windows? I'm still very interested in the details. You have my email. Thanks
09-14-2004, 01:40 AM
Ivan........
I could make them for you & send then to you if you like.
it would be 2mm or 3mm of your choice !
difference in price is.....
1 square meter 2mm Lexan = 20 Euro
1 square meter 3mm Lexan = 30 Euro
I doubt that shipping would be very expensive.
the only problem is that you cannot roll upp & down the windows
with Lexan windows.
I have mine secured with an m6 bolt/nut
but do you also want the rear window ?
K
09-14-2004, 01:42 AM
Ivan141 Wrote:I thought you had coilovers on order a while ago..my bad. I just ordered my tokico blues today, should be receiving them in a few weeks. You sure you dont mean HTS or illumina? Tokico HP (blues) would blow prematurely
if your car is lowered more than 4cm since they are full length shocks.
You do have an interesting choice of springs...most of us just buy one of the few lowering kits that are available over here.
Well...
my car is lowered 5" = 13cm.
The boxes that the shocks came in said Tokico Blue (even on the Tokico sticker)
& i have had no problems with the shocks at all yet.
09-14-2004, 01:44 AM
mux213 Wrote:Hmmm
Hey.. you have missunderstood me a little. Smile
only the rear SPRINGS of an 325 E30 will fit the AE86... not the
shocks.
Also.. A small tip --- is that the rear shocks of an NIssan Cherry Turbo will fit to 99%.. all you have to do is change the rubber bushing on the lower mount
K
09-14-2004, 08:16 AM
Hey Kristian, I understood you, just made a typo there, my mind works strange like that sometimesSmile
Those lexan windows are interesting, I still need some for my RX7...Smile
09-14-2004, 08:49 AM
Hi Kristian,
Very nice car you have there, although I liked it best when it was just a clean white car without the stickers (but then i'd like sponsors paying part of the bill as well Smile )
Could you do me a favour regarding the shocks? When you have some spare time, could you just peak under the car and measure the distance between the end of the shockbodies and the bumpstops? With the usual tokico blues this distance should be zero, thus eliminating the shocks and springs ability to do any work.
Perhaps you have some special shortened edition? If people would start to buy the ordinary blues and dropping the car 13cm they would be in for a suprise...
09-14-2004, 10:06 AM
Hi Kristian,
Great car! I bought mine also with drifting in mind Smile I also want to see the building pictures.
Have fun drifting (still downloading)
Michel
Daily driver: Seat Leon Cupra V6
Summercar: E30 M3 Cecotto
Projectcar: AE86
09-15-2004, 12:09 PM
Välkommen, välkommen Kristian! Smile
09-15-2004, 03:07 PM
Wow, that's pretty cheap for lexan! I'm assuming you wont be able to roll up the windows anymore because they lack anti scratch coating, or is it because you wanted to save weight by removing the window mechanism?
I'm going to give my friend over at GE a call, see what basic 3mm lexan would cost per square meter. At 20 euro's per square meter i can afford to replace them once in a while, as long as I can still open my windows.
I'm only doing the side windows by the way, unless lexan doesnt fog like ordinary glass does, that ,might be a reason to think about replacing the rear glass. (It's not as big of a window on coupe's as it is with hatchbacks so weight is less of a problem.)
Did you need to bend the lexan to make it fit or is it a flat piece? If it's flat I can make it myself.
  Hello from Sweden Skyracer 5 7,149 01-11-2012 07:25 PM
Last Post: Skyracer
  New guy in Sweden :) krullibull 21 24,025 05-30-2011 03:28 PM
Last Post: kennedy8383
  New member from Sweden! Bentley 12 14,674 04-30-2011 12:25 PM
  New Member. Sweden Stockholm Allexz 5 7,232 10-18-2007 05:25 PM
Last Post: S.K.
  Hello from Sweden! Hedlund 4 6,086 03-18-2007 09:26 PM
Last Post: S.K.
