KAAZ differential oil
08-04-2006, 08:57 PM
What differential oil has to be used for two-way KAAZ LSD?
AE86 GTS '84 Red Top
08-05-2006, 03:55 AM
I think you can use Motul 90PA whitout problems. I use this Oil in my Cusco 1.5 way and all OK
Regards
[Image: AEU86 AE86 - KAAZ differential oil]
08-05-2006, 01:32 PM
I use Esso GL-5 80W90 LSD oil - exactly the same spec as KAAZ oil, but MUCH cheaper. I can get you some for £5 per litre Smile
08-08-2006, 07:51 AM
Bad_Dog Wrote:What differential oil has to be used for two-way KAAZ LSD?
Bad_Dog, thanks for posting this question for me. Smile Other forum groups have also pointed Motul 90PA as a good choice. But what i noticed is that 90PA is mineral oil. Should this be a problem, is synthethic oil a better option?
1984 Toyota Corolla 4AGE 20v
2007 Subaru Impreza STi
08-08-2006, 09:58 AM
I would use nothing less than full synthetic with such an expensive rearend.
08-08-2006, 10:59 AM
in the KAAZ USA site it says:
Oil for Kaaz LSD
It is important to use 80W/90 GL-5 specification gear oil on Kaaz LSD. We highly recommend using our own Kaaz LSD fluid.
DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. Kaaz LSD may not function smoothly.
Now you chose if you want synthetic or not ....
I use Motul 90PA
08-08-2006, 11:23 AM
gon Wrote:in the KAAZ USA site it says:
"DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. Kaaz LSD may not function smoothly."
I've heard this before but did not know if it's only a rumor.
08-08-2006, 03:54 PM
a rumor publicated in the KAAZ USA official web site ?
08-08-2006, 04:19 PM
ummmmm I'll never put Syntetic oil in my LSD. The brands of lsd said than syntetic oil crapt LDSs.
Regards
08-08-2006, 04:24 PM
Can anyone come up with some links about this?
It would be a bummer if synthetics dont go well with LSD's... synthetics are a better choice for your gearlife than mineral oils.
  Differential specs MatuOjav 2 560 12-03-2025 07:06 PM
Last Post: MatuOjav
  Kaaz 1.5 way Diff - Driveshaft Compatability chrisae86 1 3,456 05-10-2021 01:02 PM
Last Post: Project D
  Rear Differential rebuild chenfon 10 13,644 11-20-2020 12:18 AM
Last Post: totta Crolla
Exclamation Some information for those who are about to restore their differential krullibull 0 4,130 06-06-2015 12:44 AM
Last Post: krullibull
  trans oil, lsd oil change Apolan 9 20,548 10-01-2014 03:57 PM
