Ivan's coupe: seeing RED
05-13-2006, 03:39 PM
Post: #171
Ivans hachi soon is going to be more brand new steel then 23 year old rust
![]() Good stuff man! I have a feeling that when I am back from HK that car of yours will have been completely transformed
05-13-2006, 08:52 PM
Post: #172
To get back to my posting about the right-arches:
I took an inventory today since I was going to wash the hachi and found out the rust behind the bumper became much worse, probably due to it not being mounted properly. To indicate the size of my problem I've drawn it on the pic attached. So, I am really interested in that particular part of your car if yours isn't gone as well.
05-13-2006, 09:29 PM
Post: #173
Banpei, the bit behind the bumper can be replaced by any bit of metal, its behind the bumper
As for the arch, auch that looks like a big hole but again I think its pretty doable with a bit of body work from another toyota that is similar to a hachi. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
05-13-2006, 10:48 PM
Post: #174
Mux213 Wrote:Banpei, the bit behind the bumper can be replaced by any bit of metal, its behind the bumperThat's true, but I figured it would be easier to replace it as a whole.
05-14-2006, 12:33 AM
Post: #175
banpei Wrote:That's true, but I figured it would be easier to replace it as a whole.Easier and better but $$$ Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
05-14-2006, 12:35 AM
Post: #176
We'll see.. the right side is not really rusted in that spot on the wheelarch..more towards the bottom of the wheelarch and around the rear light cluster. We'll just have to wait and see how the quarter panels look once they're off. I do hope to set a date for the whole operation sometime this week. If I need to order the rear panel from toyota myself, so be it.. On another sidenote I have probably found an engine that's had a lazy life behind it for a small sum..so I can remove my current oil-consuming 4AGE that has probably had a bit more abuse (some from me as well I must admit).
05-15-2006, 10:28 PM
Post: #177
My rust is a bit more upwards.
Posted the images of mine in my own topic. ![]() http://www.aeu86.org/viewtopic.php?p=43556#43556 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
05-16-2006, 07:01 AM
Post: #178
I think I'll be able to help you out with that if all goes well.
05-16-2006, 05:50 PM
Post: #179
Ivan141 Wrote:I think I'll be able to help you out with that if all goes well.Cool! ![]() Bas also opted to have a better inspection upcoming "sleuteldag"
05-18-2006, 07:03 PM
Post: #180
I guess you solved your ignition key problem. I spotted your car again today...
| Gtsi-R red'n black coupé | Gtsi-R | 147 | 181,645 |
02-03-2022 02:43 PM Last Post: Ivan141 |
| Red over Black UK Ae86 | RobH69 | 5 | 20,331 |
02-03-2011 02:01 PM Last Post: Bean |
| my 1984 red over black corolla gt | davegtcoupe | 3 | 12,714 |
10-12-2010 08:14 PM Last Post: davegtcoupe |
| Red panda coupe...rebuilded | vladx_kc | 98 | 129,755 |
07-24-2008 07:08 PM Last Post: robokill |
| Red Dragon | islade | 72 | 96,870 |
03-01-2008 04:37 PM Last Post: islade |
![AEU86 AE86 - Ivan's coupe: seeing RED [Image: AEU86 AE86 - Ivan's coupe: seeing RED]](https://www.aeu86.org/sticker-banner-468.gif)
