Is my setup correct?
12-04-2006, 05:33 AM
Post: #51
NoHachi Wrote:A T3S60 will make 250hp at 10PSI.. So then generally speaking with proper intercooling, fueling, and spark 10psi is "do-able" on most USDM 4A-GE's with stock internals. If so thats all I needed to know, I wont be taking it to 10 but it gives me an idea of what is too much. Im going to have my track or high-boost set at 8psi. street will be 5. Thanks NoHachi. And thanks guys, I dont think i could've pulled this together without the help and advice of AEU86.org (Club4ag has too many know-it-alls that are too good for helping out a noobie.) I think my thread is complete. |
12-04-2006, 11:50 AM
Post: #52
Hmmm you still don't get it completely...so I wouldn't lock this one yet.
10psi is what the turbo will sustain at 10 psi..Your engine "might" survive that kind of power..provided you don't rev it out to much, your tranny probably won't. In projects like yours, with everything bodged together, no real fuelings solution, no modified timing, no knock controll, it is usually not the boost that kills the engine, but knock. Running lots of boost is certainly possible but comes at a risk. Having said that, the numbers you provided look ok..5psi and 8 psi should be ok, but you might be running the turbo outside of its efficiency area..can you try and find the efficiency map for your particular turbo.We can take a look at it together and see whether you would be better of switching.. A wheel to steer the front of the car A pedal to steer the rear |
12-04-2006, 05:25 PM
Post: #53
Okay, but i think ive got the knock handled.
Ill be getting E-Manage U soon to play with timing and manage AFR I have big injectors with a big pump, I have changed sparkplugs and wires, I have a FMIC. Running Canadian 91 octane. Isnt that the knock down? I know its not essentially the boost that kills a motor. And I WONT be running 10psi, I just wanted to know where to generally draw the line with 4age's |
| Correct connection brake master cylinder? | bozu | 5 | 10,337 |
| 4 Link setup and Traction brackets | Jezza_hr | 5 | 13,765 |
07-21-2014 09:12 PM Last Post: Bean |
| DIV 1 rally/track suspension setup | ditn | 60 | 97,073 |
03-28-2013 11:28 PM Last Post: ditn |
| Fuel system setup | 86Pilot | 2 | 6,777 |
01-30-2013 04:24 PM Last Post: Bean |
| MSD 8980 setup - which wire does the dizzy connect to? | megabob | 8 | 21,416 |
11-22-2011 07:02 PM Last Post: Project D |
