Injector sizes info
12-09-2004, 04:19 PM
Injector sizes info
I've found this information about 4a-ge injector sizes.
http://www.geocities.com/MotorCity/Pit/9...ctors.html
[Image: AEU86 AE86 - Injector sizes info]
"How many injectors can one guy have? Well I found out pretty early that the standard 215cc/min Beige injectors (top right) weren't going to deliver enough fuel for the new cams. I tried the Supercharger 4AGZE 365cc/min Orange injectors (Bottom right) but they were just too big and was causing the ECU to go into limp home mode. Finally I got a set of 100kW Green 250cc/min injectors (Bottom left) and that did the trick. "
Source: http://www.geocities.com/MotorCity/Facto...ampics.htm
CC / MIN COLOR OHMS lbs / HR kPa APPLICATION
365 red/orange 2.9 33.9 255 4AGZE
210 blue 2.4 20.6 255 4AGE
200 pink 2.7 19.6 290 4AGE
182 dark grey 2.0 17.8 255 4AGE
250 green 13.8 24.5 290 4AGE
250 purple 13.8 24.5 290 4AGE
213 beige 13.8 20.9 290 4AGE
155 violet 13.8 15.2 290 4AFE
Source: http://www.toysport.com/webpages/Techinf...ectors.htm
12-09-2004, 06:39 PM
Injector sizes info
nice list needed this sooner :-) i want 295 CC injectors with 272 duration cams .. :-)
12-09-2004, 09:32 PM
Injector sizes info
I think I have a set of those green injectors at home, are those from early ae92's with bluetop?
12-13-2004, 06:38 PM
Injector sizes info
Ivan141 Wrote:I think I have a set of those green injectors at home, are those from early ae92's with bluetop?
if these are the genuine green 250cc injectors... Ivan man - just give me a price - NOW: Hurray!
12-14-2004, 01:34 AM
Injector sizes info
Sorry, just took a closer look, they are just slightly discoloured beige ones. Otherwise I would have used them myself..
01-05-2005, 02:18 PM
Injector sizes info
If you use adjustable FPR (fuel pressure regulator) - you can fine tune your injectors rate :-)
http://www.avcweber.gr/malpasi/weber11.htm
I have RP12 from wrecked FORD engine - it cost me only ~15EU and fits to bigport 4AGE fuel rail !
01-05-2005, 02:27 PM
Injector sizes info
I think I will be needing some bigger injectors too Sad Crying
Does anyone know if other cars use the same type injectors as the 4AGE ?
Regards Ian.
01-05-2005, 02:30 PM
Injector sizes info
Ian.G Wrote:I think I will be needing some bigger injectors too Sad Crying
If you go turbo - you may use 440 cc Supra Turbo 7MGTE injectors - they FIT to the rail, 2.6 ohms, are cheap at Ebay and are available.
08-31-2008, 12:37 AM
Injector sizes info
MAKE IT A STICKY PLZ!
08-31-2008, 09:30 AM
Injector sizes info
So which bigger injectors can we connect on the bigport wiring injector? I want to fit bigger injector without mods.
**COROLLA EE80 - 4AGE 124HP**
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 7,313 11-05-2016 01:34 AM
  Injector voltage problem [fixed] d3nso 16 24,311 04-03-2016 12:39 PM
Last Post: d3nso
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 7,653 02-20-2016 11:48 AM
  frame/chassis rails info Tig 14 27,096 12-22-2012 10:38 PM
Last Post: Tig
  pink injector resistance Apsogos 2 5,434 10-01-2012 09:00 AM
