Info on spring spacers
06-02-2006, 11:20 PM
RoninMax Wrote:This Rear Spring Spacer is to control the ride height in mind first, but also for secure the rear spring (using TRD Rear Spring, etc) if you are not using short stroke shock such as TRD Rear Shock 8 ways Adjustable (48531-AE831). Could you tell me do you supply these shocks ? if not maybe a european supplier ? |
06-03-2006, 12:29 AM
I do can get them also, but it is really expensive. The price in japan is around 18000 Yen each rear shock. Please keep in mind that those shocks are race only and it will be stiff on the street even on the softest setting.
Maxwell Arancon Vice President PASS RACING INC 148 S.8th Ave, Unit-F City of Industry, USA [email protected] http://www.passracing.com ![]() |
06-03-2006, 06:55 PM
Hi Kipsy, I have used some strong cable ties to stop front spring dislocation on my 86 but I'm not sure they are strong enough.... was going to find out tonight on the Wessex road rally but it's been cancelled !
The handling of the car seems very odd and I'm putting it down to the front springs being about 15mm shorter than the strut leading to spring dislocation. The car is very 'pointy' but also seems to 'float' especially on undulating roads, it is fine over the very rough stuff. It is running new Bilsteins all around with 190lb springs front and approx 160's rear. Could it be wheel alignment ? I have a very small amount of front toe out. What do you think ? An analogue brain in a digital World |
oops
![]() An analogue brain in a digital World |
06-06-2006, 09:58 PM
RoninMax Wrote:You can get them from us. Let me check the price first.Have you got any idea about the price yet? ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-08-2006, 08:00 PM
I check on the price and I bought 1 set of the 10mm Dog Fight Pro Rear Spring Spacer. It is cost 125 USD for it (The cheapest one of all the size, kind of expensive). Sorry I did not check the rest of them. I think I will just make some of those if the market is there.
06-08-2006, 09:39 PM
Auch.
![]() I think I'll pass then... Just as Mux said: more expensive than getting a set of custom springs. ![]() Thanks for finding out btw ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
06-08-2006, 09:49 PM
I know those are expensive, That is the reason why I bought that and try to make some of those for much more reasonable price. I think I will be selling with the B-tune X Swift spring so people can use those spring for the reg stroke shock. Also I will post some pic later for different between OEM, TRD & Btune X Swift rear spring for reference.
06-09-2006, 10:36 PM
Ah, I see.
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 5,578 |
SOME 4AG valve spring specs | oldeskewltoy | 5 | 14,416 |
05-04-2015 01:17 PM Last Post: Project D |
clutch pedal return spring | Eifelaner | 2 | 7,864 |
09-06-2013 10:21 AM Last Post: Apsogos |
Injector sizes info | ZaX | 19 | 38,612 |
4age fuel rail spacers | kpretro84 | 5 | 8,993 |
03-16-2013 08:30 PM Last Post: Bean |
