Impreza Group-N project.
08-18-2008, 11:41 PM
Post: #141
Started working on the brake lines
I had to get some stuff before I could start, so I went to the scrapyard and took nipples I needed, from the newest cars they had, coz then they are still shiny. ![]() I also took 2 T-pieces which cost almost 40 euro a pop at the shop. Nipples: ![]() T-pieces: ![]() ![]() Looks like donkey balls, so I polished them a bit. As new!!: ![]() ![]() Everything together, in the shop almost a 100 euro's, at the scrapyard 10 euro. ![]() I found the measurements of the AP-Racing brake fluid reservoirs I am going to buy, so I turned a dummy from plastic: ![]() Friend of mine had a "bead" machine which I borrowed, but before using it the line had to be cut off: ![]() This is how it works: ![]() ![]() ![]() ![]() ![]() ![]() For assisting me with the shape I found a piece of solid core wire. ![]() Then the real work started: ![]() ![]() ![]() This was ok, but I wasn't really satisfied. So today I redid the whole thing, and now I iz happeee: ![]() ![]() ![]() Now the rest. |
08-19-2008, 12:02 AM
Post: #142
08-19-2008, 10:02 PM
Post: #143
08-21-2008, 07:43 AM
Post: #144
wow....went thru the entire thread. i commend you on some awesome fab work
08-21-2008, 08:52 AM
Post: #145
Thank!
08-21-2008, 07:47 PM
Post: #146
Im Imprezzed!
08-21-2008, 11:35 PM
Post: #147
you'r crazy, i loving it
08-27-2008, 07:19 PM
Post: #148
Yeah, for some reason the "beeing crazy" comment seems very populair these days.
But my shrinks say it's not true and I'm perfectly normal.
09-14-2008, 10:40 PM
Post: #149
Small update,
Did another small piece of brakeline, the part to the left front wheel: ![]() AP-racing fluid reservoirs have arrived, my dummy worked pretty good I must say!: ![]() ![]() ![]() An air exit for the bonnet, WRC replica. ![]() ![]() This is something else that crossed my path, a new cable for the battery. It's aluminum with a silver coating, used in proffesional racing apparently. A bit bizarre, it's fingersize but weigh's nearly nothing:
10-10-2008, 06:55 PM
Post: #150
FMIC time!
This job was sidelined for a bit but today I got some inspiration again. The endtank attachments had to be worked. There was a difference in width between the cores, so after contemplating a bit it was decided to change them altogether and make them as small as possible. So a tool was made and used: ![]() ![]() ![]() The IC needed to be heated up so the material would get softer and more workable. Fire up the ovens: ![]() Unfortunatly it cooled down rather quick, so I used a torch later. Mutilated a plier: ![]() ![]() First flattening occured :![]() ![]() After that my new tool came into action: ![]() Viola, the result and difference: ![]() ![]() ![]() ![]() Next week I'll rework the radiator the same way. Now the 2 cores have to be welded together which is pretty risky, if that fails all this work has been done for nothing! Received some parts today, alloy tube and connectors: ![]() Next week more parts should follow, so more updates then.
| 1984 Celica turbo b-group restoration | Roger | 8 | 13,145 |
04-24-2010 05:09 PM Last Post: corolla4agze |
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/288b21ff.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/f11299ee.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/37ccfcfd.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/08ffb2e9.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/ae6e3e13.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/68e5793c.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/245dfc02.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/c6e28c41.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/16ebeb56.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/a76b3dc2.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/45150cb0.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/e10169b7.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/d596d2c7.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/943ea116.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/d3285f36.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/a7e1c032.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/05f71a4b.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/8efed49a.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/d17fc656.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/a1b47793.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/f07bec1d.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/61b6ea4a.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/06d89bba.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/768f2b57.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/ae98e6fa.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/75e6e9a5.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/Project%20Group-N/75ec521f.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4509.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4510.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4512.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4517.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4514.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4515.jpg)
:![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4518.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4519.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4527.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4524.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4522.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4525.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4521.jpg)
![AEU86 AE86 - Impreza Group-N project. [Image: AEU86 AE86 - Impreza Group-N project.]](http://i29.photobucket.com/albums/c281/Tranquill/IMG_4528.jpg)
