Impreza Group-N project.
08-18-2008, 11:41 PM
Post: #141
Started working on the brake lines
I had to get some stuff before I could start, so I went to the scrapyard and took nipples I needed, from the newest cars they had, coz then they are still shiny. Wink
I also took 2 T-pieces which cost almost 40 euro a pop at the shop.
Nipples:
[Image: AEU86 AE86 - Impreza Group-N project.]
T-pieces:
Looks like donkey balls, so I polished them a bit.
As new!!:
Everything together, in the shop almost a 100 euro's, at the scrapyard 10 euro. Big Grin :
I found the measurements of the AP-Racing brake fluid reservoirs I am going to buy, so I turned a dummy from plastic:
Friend of mine had a "bead" machine which I borrowed, but before using it the line had to be cut off:
This is how it works:
For assisting me with the shape I found a piece of solid core wire.
Then the real work started:
This was ok, but I wasn't really satisfied.
So today I redid the whole thing, and now I iz happeee:
Now the rest. Big Grin
08-19-2008, 12:02 AM
Post: #142
Thumbs up! looks n1. good going on the dummy
08-19-2008, 10:02 PM
Post: #143
Cool
08-21-2008, 07:43 AM
Post: #144
wow....went thru the entire thread. i commend you on some awesome fab work Thumbs up!
08-21-2008, 08:52 AM
Post: #145
Thank! Big Grin
08-21-2008, 07:47 PM
Post: #146
Im Imprezzed! Tongue
08-21-2008, 11:35 PM
Post: #147
you'r crazy, i loving it Tongue
08-27-2008, 07:19 PM
Post: #148
Yeah, for some reason the "beeing crazy" comment seems very populair these days. Big Grin
But my shrinks say it's not true and I'm perfectly normal. Tongue
09-14-2008, 10:40 PM
Post: #149
Small update,
Did another small piece of brakeline, the part to the left front wheel:
AP-racing fluid reservoirs have arrived, my dummy worked pretty good I must say!:
An air exit for the bonnet, WRC replica.
This is something else that crossed my path, a new cable for the battery.
It's aluminum with a silver coating, used in proffesional racing apparently.
A bit bizarre, it's fingersize but weigh's nearly nothing:
10-10-2008, 06:55 PM
Post: #150
FMIC time!
This job was sidelined for a bit but today I got some inspiration again.
The endtank attachments had to be worked.
There was a difference in width between the cores, so after contemplating a bit it was decided to change them altogether and make them as small as possible.
So a tool was made and used:
The IC needed to be heated up so the material would get softer and more workable.
Fire up the ovens:
Unfortunatly it cooled down rather quick, so I used a torch later.
Mutilated a plier:
First flattening occured Smile:
After that my new tool came into action:
Viola, the result and difference:
Next week I'll rework the radiator the same way.
Now the 2 cores have to be welded together which is pretty risky, if that fails all this work has been done for nothing!
Received some parts today, alloy tube and connectors:
Next week more parts should follow, so more updates then. Smile
  1984 Celica turbo b-group restoration Roger 8 12,211 04-24-2010 05:09 PM
Last Post: corolla4agze
