Impreza Group-N project.
01-01-2009, 11:01 PM
Post: #181
that sucks! Sad
bad about the lost parts too! Sad
01-02-2009, 10:52 PM
Post: #182
Auch... Lucky there were only parts in the factory and not employees.
[Image: AEU86 AE86 - Impreza Group-N project.]
02-22-2009, 04:06 PM
Post: #183
A friend of mine who works with fibers made a hood for me, molded from a non-turbo model.
When the rad pack set-up is fixed to the car he will also help me make the cladding from the bumper to the IC and from the radiator to the hood.
When that's done we will finish the front end of the car concerning panelgaps.
This is more important than most people realise I think, when the gaps are uneven or different in size ultimately the end result will look unfinished and unproffesional and that's defenitly not what I want!
Pics:
greets.
04-16-2009, 09:37 PM
Post: #184
Today I got a present from the cranedriver who is tearing down the old building.
A Brembo brake caliper!
It was in the hottest part of the fire but it seems to be "unscratched".
Even the seals are still in.
Time for a cleanup!
04-16-2009, 09:46 PM
Post: #185
You got just one of them?
04-17-2009, 09:24 PM
Post: #186
Yip, the haven't found the other one.
04-18-2009, 12:12 PM
Post: #187
whowie... sucks to hear about the fire... well calipers generally are designed to take alot of heat, but still, not sure if I would want to trust my life on breaking power after knowing the history of these brakes Big Grin
Looks like she is slowly coming together though! Shame I might never be able to drive in her
06-03-2009, 04:27 PM
Post: #188
What a epic build! Just spent the past hour and a half reading this thread. Great work mate. Any update's?
06-08-2009, 11:27 PM
Post: #189
Hi Mack!
We'll, I've saved up some cash and ordered some parts.
So hopefully updates soon. Smile
greets.
07-26-2009, 09:43 PM
Post: #190
Small update.
Not actually the car itself this time, but something that will help build the car when it's done and works.
I removed a welder from the burned factory, it's a Fronius Magic Wave 3000 Job.
It was a year old and apart from 2 parts and alot of smoke it seemed to be fine.
I don't know if it works yet, but I cleaned it before I test that anyway.
2 reasons for that, the smokedust can conduct electricitity and there was cristal forming everywhere, also between the components on the circuit boards, so to reduce the chance of a shortcut I cleaned it anyway.
This is how it looked when I got it:
And then dismantling it:
Undertray:
The alu plates were acid cleaned, the bolts yellow plated and the circuit boards proffesionaly cleaned.
The casing I left as is for now, first I want to know if it works.
The parts cleaned, note the white on the alu parts, it is corroded by the chlore in the water that they used to put out the fire, nasty stuff :
Building again:
That's it sofar, this week i'll test it, then if it doesn't explode I will order some parts that I need to actually weld with it, and if that works I will clean the rest.
  1984 Celica turbo b-group restoration Roger 8 13,116 04-24-2010 05:09 PM
Last Post: corolla4agze
