Idle speed problem
01-11-2006, 08:36 PM
Idle speed problem
Hello all,
I got some problem with my idle speed. First of all, I am too noob with car. So my problem is, when my engine warm the idle speed going up and down between 1500rpm and 1700rpm. This happend only when the car idle/stop and while driving is ok but when I press clutch pedal its happen again.
Things already done:
Flushing my radiator few times, resevoir coolant are about full line now.
Checked and renew few rubbers that connected to TVIS. Just found 1 rubber are leak.
I dont know which 4age engine I got in my car Banging head but you can look here:
http://oldskull.sytes.net/ul/DSC03965.JPG
http://oldskull.sytes.net/ul/DSC03915.JPG
I hope I can fix it myself with your help. I am going back to the first owner, but its take awhile to go there seems he also busy with work.
Any help and suggestion are welcome, thanks
01-11-2006, 10:21 PM
Idle speed problem
AFM 4AGE (not MAP).
01-11-2006, 10:23 PM
Idle speed problem
Where are you from?
You should have the SDZ market (Swiss and Sweden) engine with AFM (airflow meter). The others have map (manifold absoulte pressure)...
The diference between SDZ 4AGEC and californian 4AGEC is that the the SDZ doesn't have o2 sensor and catalytic converter. The third line on the tvis intake manifold has a cap - in California this is a cruise control...
Regards
Andrej
01-11-2006, 10:41 PM
Idle speed problem
I am now in Holland. Yes the car was from Swirtzerland, the owner bring the car to holland in 97 if I am not wrong.
01-11-2006, 11:07 PM
Idle speed problem
What about your temperature reading? Is it normal? It should be a little below half on the meter when the engine is warm.
[Image: AEU86 AE86 - Idle speed problem]
01-11-2006, 11:28 PM
Idle speed problem
The temperature are normal, yes it is little below half on meter
01-11-2006, 11:29 PM
Idle speed problem
a low level off coolant give this problems.
Starlet p8 si turbo @ 1.0 bar grey 6,4 sec-> 100
Starlet P9 si turbo @ 1.2 bar black 5,8 sec-> 100
KTM 950 SE ->100 3,2 sec 105 Db Tongue
xt660r ->100 4,5 sec
BMW 1100 GS->100 4 sec
01-11-2006, 11:32 PM
Idle speed problem
ae86 Wrote:a low level off coolant give this problems.
I already read this too somewhere, but I dont know what its means. If its mean coolant by resevoir tank (white tank) than it is almost on full line.
01-11-2006, 11:35 PM
Idle speed problem
Hi.
My i think you should readjust the tps. look ind the manuel how to adjust it. I cant remember the settings for it, but my car had a "rolling idle" and I adjusted the tps, and it was just fine..
Lasse
I still play with cars......
01-11-2006, 11:39 PM
Idle speed problem
@lasse: could you tell me where TPS is and maybe pic would be helpfull too as I write that I am totally n00b
EDIT: After some searching, I think I found what TPS is, it is Throttle Sensor?
EDIT 2: If its right, I think I would give a try. I found it here:
http://translate.google.com/translate?u=...uage_tools
http://www.ae92gts.com/ae92gts_tps.html
Maybe someone here in Holland can help me?
Thanks in advance
  Blacktop 20V high idle Bravothreezero 3 889 08-28-2026 01:11 PM
Last Post: jdm86gtz
  No idle below 2000 rpm rich running Steller Engineering 3 4,299 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 15,021 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 11,470 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 7,648 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
