Idle problems
02-21-2009, 10:57 PM
Idle problems
I know it has often been discussed here , I've got Idle problems .
The engine revs up and down from idle to about 2700rpm. First of all , I swap my broken engine with a second hand one . All periphericals are mine, from former engine . I made a research here and found that the problem comes very often with cooling system . So I check the cooling circuit , but found nothing . Here's a list of parts I change to try correcting that problem : -Intake air sensor -water temp sensor -start injector start time -Vacuum Sensor -VSV for idle up Injectors , Throttle(including TPS) , and air colllector are same as the engine I broke , as I had no problem ! When idle move from low to high revs(+/- 2700rpm) I removed the Vacuum sensor hose and the idle was stablt . As soon as I got the hose on , the moving idle is back . I also swapped 3 or 4 distributor , whithout success . Any idea where to look at ?? I'm really desesperate and in a hurry for my next rally Filh Filh Save the RWD cars |
02-21-2009, 11:44 PM
Idle problems
its normal when start the engine to be 2700revs and after down
**COROLLA EE80 - 4AGE 124HP**
02-22-2009, 01:00 AM
Idle problems
I don't speak about cold start but engine at normal temperature ( 80 c°) of course!
02-22-2009, 06:44 AM
Idle problems
the valve under the throttlebody maybe?
whenever someone asks about idle problems on other forums people always say it has to do something with that valve. |
02-22-2009, 10:30 AM
Idle problems
Try winding out the idle air screw (the one down the hole on the side
of the throttle body). Oh, and the other thing that you should try, is blocking off the idle air bypass port in front of the throttle butterfly. While the engine is running just block it off with your finger, and see if the idle stabilises. If it does you need to strip and clean/replace the thermostatic idle-up that bolts to the underside of the throttle body (the part that the two small water hoses connect to). Cheers... jondee86 |
02-22-2009, 11:53 AM
Idle problems
Those two small water hoses also get clogged up sometimes...
02-22-2009, 03:38 PM
Idle problems
thanks for helping . I read a lot on Club4age forum , and the same part is often pointing out : the AAV (I guess Additional Air Valve) .
I think it's located under throttle body ? How do you clean it ? Isn't it a sealed one? About the two little water hose , there should be coolant in if not clogged ? And last questions often discussed : As it's an other engine , I had to fill the coolant system , but it seems that a bleeding is needed ! I read several way of doing it , what's yours ? Thanks again for spending time answering . Next rally season begin in two weeks , and I'm nowhere now Phil Filh Save the RWD cars |
02-22-2009, 04:01 PM
Idle problems
if i bleed my system, i start and run it with the cap off, and the heater turned on. Let it warm up untill the thermostat opens and keep an eye on the level in the rad.
02-22-2009, 07:55 PM
Idle problems
Have a look at this thread... http://www.aeu86.org/viewtopic/heater-pi...highlight=
Note my comment regarding the supply of hot water to the Auxiliary Air Valve. You may have a blocked water pipe. However, if hot water is circulating through the AAV, it's possible that the valve [thermostat] no longer works. To check it, remove your throttle body, and unbolt the AAV. ![]() The AAV [the bit with the pipes coming out of it] can be seen screwed to the side of the TB in the above pic. ![]() ![]() Put the AAV in some hot water to see if the valve closes. If it doesn't, replace the AAV. HTH |
02-23-2009, 01:00 AM
Idle problems
Thanks a lot , I just remove the throttle body and will check tomorrow , to see if the AAV work .
| Blacktop 20V high idle | Bravothreezero | 2 | 230 |
08-10-2026 04:58 PM Last Post: ondafly |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 3,956 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 14,025 |
| Big wheel problems | gh0st | 16 | 15,102 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,890 |
![AEU86 AE86 - Idle problems [Image: AEU86 AE86 - Idle problems]](http://img231.imageshack.us/img231/3387/dscf0997aq.th.jpg)
![AEU86 AE86 - Idle problems [Image: AEU86 AE86 - Idle problems]](http://img231.imageshack.us/img231/5468/dscf0992a.th.jpg)
![AEU86 AE86 - Idle problems [Image: AEU86 AE86 - Idle problems]](http://img100.imageshack.us/img100/4162/dscf0987a.th.jpg)
