Idle not going smooth...
06-10-2011, 08:31 AM
If the level of brake fluid is low, the handbrake light will also light up!
http://monkeymagic86.wordpress.com |
06-13-2011, 10:40 PM
Ok, so I changed the plugs, I noticed plug No. 1 is sooooo black, put in new ones unplugging the wires one by one, when removing wire No. 1 there is no change, cranking is the same, and the temperature jumps to third after 5 minutes, alternator is working fine.
so what is it? failed injector, plug wire? and the brake light is still ON |
| Blacktop 20V high idle | Bravothreezero | 3 | 580 |
08-28-2026 01:11 PM Last Post: jdm86gtz |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 4,078 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 14,385 |
| exhaust odor/idle MOT issue | Ryo | 7 | 11,174 |
| 20v silvertop idle issue | AlexFourTwenty | 3 | 7,474 |
