Idle not going smooth...
05-16-2011, 06:59 PM
Hey, i have a question for you guys that probably know allot more about AE's than me.
I recently changed the oil/filter on my AE86. 10W40 Full synthetic oil. But still i have this question popping on my head. My idle engine sound is not smooth.... it goes smooth until it chokes, then goes smooth, and chokes a bit.... it's like it has been tweaked to accept more fuel on the injectors. And my question is, how can i adjust the fuel admission on the engine? I'm with 159k km's atm. Later i can record some idle moments.... Regards |
05-16-2011, 07:15 PM
Is your ignition set allright? If it´s advanced to much it could cause such behavoir... I´d also check the sparkplugs, dizzy cap rotor maybe one cylinder only fires randomly? Did you take a look at the spark plugs are they all coloured normal?
If you haven´t done anything else, beside the oil change start with these general service things ![]() "Fuel admission", what exactly is that? Are you talking about the CO potentiometer? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-16-2011, 07:31 PM
Hi,
I had problems with the idling revs not being constant sometimes. I replaced the rubber-cups from the injectors. They were leaking so "false" air came in. After replacement it idles like new ![]() Parts are still available at TPC, price was around 20Euro I think. Good luck with it. |
05-17-2011, 11:01 PM
I've checked the spark plugs, and its all going smooth there... When i bought the car, it was said do me that because it had a conic air filter, it was tweaked to admit more gas... Dunno where they changed those settings, and the topic was to try to find some answers for that...
05-18-2011, 01:16 AM
The only thing to change would be CO-potiometer. But it´s unlikely to cause unstable idle...
What´s with the ignition stetting? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
05-18-2011, 02:39 AM
Putting a resistor in series with the ECU water temp sensor used to
be a favourite way of getting more gas into the engine. The resistor (and sometimes it was a small rotary pot) makes the ECU think that the engine is cold, and it richens the fuel mixture. Maybe you can go to a garage with a tailpipe WBO2 probe, and have them measure the AFR's to see if you are running rich ?? Cheers... jondee86 |
05-19-2011, 12:12 AM
I've made a video so you can hear my idle sound..
http://www.youtube.com/watch?v=Jc7S9-Bp4mE What you guys think?! |
06-10-2011, 01:55 AM
same thing here, exactly, after changing oil and filter, handbrake light is on all the time, checked plugs, dizzy, timing, injectors, intake manifold, all fine, it happened after changing the oil and filter, I thought the guy accidentally cut a wire, checked all wires but nothing new.
it's been a week now, can't drive the freaking thing. |
06-10-2011, 02:35 AM
adenAE86 Wrote:same thing here, exactly, after changing oil and filter, handbrake light In some markets I understand that if the handbrake light and the check engine light remain on, it means that your alternator is not charging Might be worth checking the voltage at the battery, and making sure it rises to 13.6V (or something like) after the engine has started. Cheers... jondee86 |
06-10-2011, 04:02 AM
thanks jondee86,
will check that and get back to you. cheers |
| Blacktop 20V high idle | Bravothreezero | 2 | 186 |
08-10-2026 04:58 PM Last Post: ondafly |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 3,918 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 13,912 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
| exhaust odor/idle MOT issue | Ryo | 7 | 10,981 |
| 20v silvertop idle issue | AlexFourTwenty | 3 | 7,328 |
12-24-2017 03:27 AM Last Post: AlexFourTwenty |
