INjector Guide
12-16-2005, 07:37 AM
INjector Guide
Morten Wrote:That calculator is missing one important thing: max. rpm
Reason is that when the rpm increases the time available for the injector to spray the needed gasoline is decreasing. Hence a engine with max output at 9000rpm needs injectors 50% bigger then an engine with max output at 6000rpm to support the same amount of horsepower (at same dutycycle).
I would think the calculator is based on a "normal" rpm of 6-7000, but it does not state anything about it.
Just a little something to keep in mind when choosing injectors.. :wink:
This is actually incorrect. Power output and fuel consumption are closely linked, but the RPM has nothing to do with it.
So if two cars have the same injectors and fuel pressure regulator and one produces 200hp at 5000rpm and the other produces 200hp at 9500rpm then their max injector duty cycle should be the same.
Sure at high RPM, you have a smaller time to inject per stroke, but you have more strokes per second, so hence a greater number of injection pulses per second.
Hen
No, this thing is totally stock standard officer...
12-26-2005, 01:36 AM
INjector Guide
Hen Wrote:This is actually incorrect. Power output and fuel consumption are closely linked, but the RPM has nothing to do with it.
Hen
Good point! It seems I spoke before really thinking this completely through.. by bad Confused
However, in real life it would actually be something in between due to injector lag times taking a larger and larger percentage of the available time as the revs rise.. Tongue
'85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 19,436 02-10-2020 06:39 PM
Last Post: Power_uP
  Injector voltage problem [fixed] d3nso 16 25,598 04-03-2016 12:39 PM
Last Post: d3nso
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 7,960 02-20-2016 11:48 AM
  Injector sizes info ZaX 19 45,291 07-17-2013 01:54 AM
Last Post: jondee86
  pink injector resistance Apsogos 2 5,661 10-01-2012 09:00 AM
